72 roller rockers
Old Oct 21, 2010 | 11:26 AM
prg1969's Avatar
prg1969
Default 72 roller rockers
I have 72 that has had its hyrdraulic lifters replaced with solid, but it still has the stock rocker arms. Is it fairly easy to install roller rockers on the heads.
Old Oct 21, 2010 | 11:52 AM
crf311's Avatar
crf311
Remove and replace, then adjust. Although you may need different pushrods.
Old Oct 21, 2010 | 12:03 PM
Timsride's Avatar
Timsride
You will also have to go to tall valve covers if You havent done so already.
Old Oct 21, 2010 | 02:45 PM
64 roach's Avatar
64 roach
Thanks guys
Old Oct 21, 2010 | 03:18 PM
MelWff's Avatar
MelWff
are you saying you still have a hydraulic grind cam but are running solids on it?
Old Oct 21, 2010 | 05:35 PM
Gordonm's Avatar
Gordonm
Don't expect to see any HP gains by going to roller rockers. Did they swap the cam or just the lifters. If it is just the lifters you are in for some real trouble ahead. There really is no need to go to a full roller rockers unless you are running high spring pressure.
To 72 roller rockers
