Large Clunk when upshifting
Old Oct 21, 2010 | 03:48 PM
Stooney's Avatar
Stooney
Default Large Clunk when upshifting
1980 - 305 - Auto Trans
When my car upshifts without me accelerating much, it makes a loud clunk noise that comes from the rear of the car. I can visualize what is happening (rear-end mounts loose? or something) but I have no idea what is technically wrong (to start pricing the fix).
If I'm accelerating pretty quick, there is no clunk when shifting.
Also, is this serious?
Old Oct 21, 2010 | 03:51 PM
MelWff's Avatar
MelWff
check the front rear end mount for a worn bushing
Old Oct 21, 2010 | 04:26 PM
Stooney's Avatar
Stooney
http://www.ecklers.com/corvette-rear...1963-1982.html
This the bushing you're referring to? I'm no mechanic but I'm definitely learning as much as possible
Old Oct 22, 2010 | 09:21 AM
Rotonda's Avatar
Rotonda
No, the bushing you are looking for is at the front end of the differential. This bushing will deteriorate and allow the differential to rotate up and down in use. This is the clunk you hear.
Old Oct 22, 2010 | 10:10 AM
...Roger...'s Avatar
...Roger...
with above. This is the one you need.
http://willcoxcorvette.com/product_i...ducts_id=12141
Old Oct 22, 2010 | 10:51 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
if its the front of the differential bushing it will also clunk when putting it into reverse. use lock tight on this bolt when you replace the bushing, you would be surprised how many of them loosen up over time.
Old Oct 22, 2010 | 10:59 AM
Peterbuilt's Avatar
Peterbuilt
I could be the differential bushing or or the bolt could be loose or a U joint or something else, take a look before you order any parts.
Old Oct 22, 2010 | 11:24 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
I agree diff mount , did one last night on an 81, if you want pics send me an e-mail .Ron
Old Oct 22, 2010 | 11:45 AM
redstingray74's Avatar
redstingray74
Default Clunk as Shifting takes place
Yes the front mounting set-up on nose of rearend , I found this to be
totalliy shot and MISSING the big rubber when I got my '74 four speed.
Installed new stuff out of Urethane rubber and It was like another car.
Be sure to check the two threw-bolts in that bracket also ? They
need to be heathy and tight on front of rear housing .
To Large Clunk when upshifting
