Ac question
Old Oct 25, 2010 | 07:47 AM
justatoy's Avatar
justatoy
Default Ac question
ON my 73 turn ac switch and compressure does not click nothing happeneds where do i ..thanks
Old Oct 25, 2010 | 07:34 PM
71406's Avatar
71406
I would start with the basics. Put a test light on the wire going to the compressor. Are you getting power to the compressor? If yes and it still doesn't work, check the ground at the same connection. If good is it's probably the magnet in the clutch assembly. If no power, it could be a fuse or the switch inside the A/C switch on the console.
Old Oct 26, 2010 | 10:59 PM
Jack Wood's Avatar
Jack Wood
Default Could be a relay. Swap that one for a known good one and see.
How's the freon? Low pressure switches saftey will not allow the compressor to cycle if your freon level is low.
Old Jan 8, 2011 | 05:36 AM
justatoy's Avatar
justatoy
update found bad seal replaced fixed..
To Ac question
