so are these problems only i have???
Old Apr 3, 2002 | 02:40 AM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
Default so are these problems only i have???
several problems on my '81 i haven't been able to figure out, maybe some of you guys have seen, fixed and recognize.
1) my intermittant setting on my wipers doesn't work, or the mist (one wipe) setting.
2) my battery light always glows (although you can only see it at night), even though my alt is putting out 13.5-14volts. it's not bright, but you can see it.
3) my gas gauge bounces anytime the car is in motion. it generally ranges anywhere from a 1/4-1/2 sweep of the gauge but the only time it doesn't bounce is after the car has come to rest or its either really full or really empty.
these are all really just petty annoying little things, mechanically the car is fine despite being 20+ years old.
Old Apr 3, 2002 | 10:37 AM
jerryp58's Avatar
jerryp58
Default Re: so are these problems only i have??? (clutchdust)
1. Bad switch? Unless it's related to #2
2. Bad ground?
3. Bad sending unit.
Fortunately, I don't have #1. Well, could be unfortunate, since I don't even have intermittent wipers (nice feature).
I've had #2 before and seen similar "idiot" lights light up.
I think I've got #3 right now. Although, mine usually just sits at the correct reading for a few minutes and then jumps to full and stays there until I shut the car off :rolleyes:
Old cars, ya gotta love 'em :yesnod:
Old Apr 3, 2002 | 10:45 AM
fontking1a's Avatar
fontking1a
I'm waiting on the sending unit (#3) for my '69 right now. The gas gauge was working just fine until I had some bozos work on the wiring under the dash. They did fix the wiring but then the gas gauge didn't work. Coincidence? Maybe. Sometimes you wind up trading one problem for another.
Old Apr 3, 2002 | 12:10 PM
ROD NOCK's Avatar
ROD NOCK
Clutch-
1)- Most likely it's the wiper delay module's bad.
2)- The 'batt' light shouldn't glow at all. You could take alt to auto parts for testing. I suspect a poss bad diode.
3)- Most likely sending unit.
Thats just part of having a 20 yr old + car. Good Luck -Rod :chevy
Old Apr 3, 2002 | 12:38 PM
Gator81's Avatar
Gator81
Geez, man, you call those PROBLEMS?!? :D
On my '81, the wipers just quit one day, going from no problem at all to no workie at all. I've pretty much traced it to the delay module that is located behind the passenger seat (who the hell decided to put it THERE?). But I haven't replaced it yet. Haven't had the guts to look for one and see how much it costs.... :rolleyes:
So far, no prob with charging indicator or fuel guage.... (fingers crossed...)
Good luck! :seeya
To so are these problems only i have???
