1981 ECM Code 15
Old Oct 28, 2010 | 10:17 AM
Tommy Almond's Avatar
Tommy Almond
Default 1981 ECM Code 15
Hope all are doing well. My '81 is giving me a temporay check engine light about 2 minutes after start up and this come up to be a Code 13, Oxygen sensor but the light goes out in about a minute. But 5 minutes running the check engine light comes on and stays on and gives me a Code 15, Coolant Sensor.
Once these codes pops up the carb starts to run rich and the vette does not run likes she should. Engine temp is fine, normal so not affecting the engine temp, just the carb.
Thoughts, comments, suggestions? Waiting now to get the vette into the local shop to have him check it out if I cannot come up with solution. I have none of the meters to check the system as outlined in the '81 shop manual.
Second question, has anyone of you with an '81 bypassed the ECM system completely? I know this means a different carb and vac dist and then address the transmission lock up switch, anything else? I average only 10 miles to the gallon running 93 octane so wondering if this swap out would improve fuel mileage.
Old Oct 28, 2010 | 10:34 AM
7T1vette's Avatar
7T1vette
Change the oxygen sensor, the coolant [temp] sensor, and the thermostat. Apparently, the oxygen sensor is starting to degrade, but not totally shot [intermittant light]. The coolant sensor is only checked after a period of time where the computer assumes that it is up to temp; since it is not, it throws a code and the ECL stays lit till the engine is again shut down. That problem could be due to a thermostat that is stuck open, a bad temp sensor...or both. If those devices are old, just change them out.
Old Oct 28, 2010 | 11:44 AM
Tommy Almond
I started getting the Code 15 a week ago. Temp gauge still shows now as it did since I own this vette. From cold start temp goes up to 200/f and then drops back down to around 180/f and stays there unless in stopped traffic in hot temps then rises up to about 200 again.
Check engine light is like a clock, per the shop manual after 5 minutes of running if detected Code 15 will appear and like a clock 5 minutes it is on but temp has gone to 200 and then dropped back to normal.
Old Oct 28, 2010 | 02:24 PM
terry82's Avatar
terry82
computer temp sensor is differant than engine temp gauge.i would change the sensor.
Old Oct 28, 2010 | 08:02 PM
7T1vette's Avatar
7T1vette
180 deg is inadequate for what the computer wants. There should be a 195 deg. thermostat in the car. If a lower temp stat was installed, that is why you are getting the code. If lower than 190 deg, the computer will throw a fault and various parts of the system will not function properly and the engine management program will go into a 'default' mode instead of using actual data as it should.
Old Oct 29, 2010 | 11:55 AM
LannyL81's Avatar
LannyL81
Two temp sensors; one on the driver's side in the head, other on top of the intake manifold. Right now I cannot remember which is which...easy to check though. With engine running, disconnect one of them and if the temp gauge reading goes either to zero or full hot, then that is the gauge sensor and the other one is the one for the computer.
If the computer thinks the coolant is cold, it will richen the fuel mixture.
I have a 180 thermostat but with an non stock EPROM so I have no problem. Having a 180 stat and the stock EPROM could be a problem as was stated.
Old Oct 29, 2010 | 12:11 PM
Tommy Almond
Yes the sensor located on top of the manifold behind the air pump is for the ECM and has a black and yellow wires going to it. I do not have the meter or special tools to check this system out per the shop manual so now have car scheduled to go into local vette mechanic next week and he is going to check out entire ECM system and fix accordingly hoping to remove any other probelms or else consider swapping out carb and dist and doing away with ECM all together. Also brake booster replacement is schedule too.
My mechanic by phone feels 99% it is a bad sensor but also says the GM replacements comes with 2 white wires, not color coded so have to trace out the wires to ECM to get correct connection.
Old Oct 30, 2010 | 07:23 PM
Will's'74VetteL-82's Avatar
Will's'74VetteL-82
Replacing the o2 sensor will also give you better performance and better fuel efficiency, especially if it is really bad (Which it seems to be!).
Will
Old Oct 31, 2010 | 05:31 PM
81pilot's Avatar
81pilot
Since you asked, yes many of us have replaced the carb, dist and TCC lockup module. It is easy and not as expensive as you may think. And the answer is yes, my MPG went way up, I get 21 highway now. I don't regret removing it at all, it runs great, I don't ever have to worry about codes or sensors, or the ECM. Some guys on here seem to not like it when the 81 guys pull the computer stuff, or even recommend it for some reason, but I in my experience, it is easier by far to work on now. Do what you want its your car,,,,by the way, mine starts VERY easily, the idle is as smooth as silk, and the "driveability" is fantastic, no flat spots, the response is crisp and I love it. No regrets..
Old Oct 31, 2010 | 08:20 PM
7T1vette's Avatar
7T1vette
Just curious, 81pilot. Didn't you state in a prior thread that you ripped that system off the car immediately after you got it? That would mean that you never ran it as the stock system to begin with. True or not?
Old Oct 31, 2010 | 09:40 PM
terry82's Avatar
terry82
great gas mpg for a carb.
Old Nov 1, 2010 | 10:48 AM
81pilot's Avatar
81pilot
I may have said immediately, however, it took a while to gather the parts, so I drove it about 6 months or so. And all the way back from Arkansas the day I bopught it, so I think that was ample time to gain an informed decision as to what I wanted to do.... Why is it everytime anyone ASKS about pulling the computer system on an 81 you get your panties in a wad? Just sayin, I really don't care what people do with thier own car.....
Old Nov 1, 2010 | 10:53 AM
7T1vette's Avatar
7T1vette
Just reporting what I've read from you in the past. Consistency is important to gaining credibility. And, I didn't indicate anything about the poster 'losing' the CCC if he wanted to...did I?
Old Nov 1, 2010 | 11:06 AM
jdp6000's Avatar
jdp6000
Don't worry about the wire colors. Clip the old ones and connect with the new. I'll look at mine later and let you know what colors I ran but I don't think it matters.
The only other possibility is low coolant. If the rad isn't full the sensor will malfunction.
O2 is plug anf play.
Both sensors are cheap and easy to replace. Both are critical for fuel/air mixture.
Jim
Old Nov 1, 2010 | 03:02 PM
81pilot's Avatar
81pilot
I didn't know that every time I have a casual conversation on an internet forum, that I was under deposition for you when it comes to computers on 81 models(which is the topic you always jump in on with me). Immediatley in relation to planning on keeping something for a long time, is a purely subjective timeframe. Please feel free to criticise everything I say, did you not even see where I italicised things so as to indicate my opinion? I am glad I have better things to do than go back and look up your posts, try to discern thier true meaning as I see it, then call you out on it, you really need to get a life. I deleted what I really want to say, I will keep my true feelings about you off the board. I won't even read anything from you from now on, so respond away if it makes you feel good, because I WILL NOT even look at it. Maybe it will make you more credible with those that do see it.
To 1981 ECM Code 15
