Removing gauges from bezel--Help
Old Oct 28, 2010 | 12:12 PM
LefthandedHex's Avatar
LefthandedHex
Navigator
Default Removing gauges from bezel--Help
How does the front clock adjustment stem disconnect from the assembly? It's the only thing hanging me up from removing the gauges from the bezel. I've tried pulling and turning to unscrew it, with no luck...
I've got a 1977...
Old Oct 28, 2010 | 12:52 PM
firstvett69's Avatar
firstvett69
Default clock
If yours is like my 69 it has an Allen screw in the middle of the ***, screw it out and the *** will pull off, Hope this works for you. I don't know much about 77s. Good luck.
Old Oct 28, 2010 | 03:20 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Mine is missing, I just went to check it out. The **** unscrews from the post. My post has threads where the **** was. I believe you pull the **** out then turn counter clockwise to thread it off. Anyone know where I may find a ****??
Old Oct 28, 2010 | 03:52 PM
jnb5101's Avatar
jnb5101
mine have a watchmakers size slot screw that holds the **** on-don't drop it!
Old Oct 28, 2010 | 04:57 PM
Alan 71's Avatar
Alan 71
Hi,
My 71 has the slotted screw too. You really need a eyeglasses repair screw driver to fit. I also agree... don't drop it.
Regards,
Alan
Old Oct 28, 2010 | 05:00 PM
Alan 71's Avatar
Alan 71
Hi da,
Some of the vendors list the clock **** & screw in their instrument section. $10-$11.
Regards,
Alan
Old Oct 28, 2010 | 06:15 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Originally Posted by Alan 71
Hi da,
Regards,
Alan
Thanks!!!
To Removing gauges from bezel--Help
