Engine Build specs 350cu
Old Oct 28, 2010 | 10:12 PM
richiev88's Avatar
richiev88
Default Engine Build specs 350cu
I have the following SB engine combo in my chrome bumper car
1972 010 block, Scat cast crank ,Hyperutectic pistons, flat top, edelbrock cam 278/288 #EDL2102
Rebuilt 327/350 heads small chamber, 1.6 rockers,edelbrock EPS manifold 1500-5500, 600 vac holley.
This combo pull real strong bottom through mid range, runs out a bit over 5000 rpm, but would work well for some one wanting a daily driver type build.
Has a nice lumpy idle
Old Oct 30, 2010 | 11:06 AM
ZZ71S's Avatar
ZZ71S
http://www.carcraft.com/techarticles...ine/index.html
Maybe some ideas here
