Does anyone know why Chevy used the same exhaust tips on both small and big blocks? I ask because my big block has a 2.5" exhaust system until the end of the mufflers where it has a 2" outlet. It seems to me that this would cause a restriction. On the small blocks the exhaust pipes are the same size as the outlet pipe on the mufflers but on a big block, the inlet is larger than the outlet.
Did Chevy do this just to be able to use the same exhaust tip on both engines?
I don't why GM did it, but the LT-1 is a 2.5 inch system also. It is a 2 inch manifold to 2.5 inch pipe then back to 2 inch.
Yeah, I forgot about the LTI system but nevertheless, it is the same sort of question. Chevy went to the expense of putting a larger exhaust system on and then restricted it with the mufflers and tips. The only other thing I can think of is that the exhaust will be cooler by the time it exits the mufflers so maybe the 2" outlet isn't a restriction.
It's not really that much of a restriction all the way at the "finish line" of the exhaust system. Remeber the Vette started out as a SBC car and went BB 1/2 way through C2 production, the 2" outlet wasn't that big of a restriction on a SBC car.
I have Corvette Central N-11 mufflers on my 70 LT-1 and they don't seem to hinder performance too much.
I also have run Walker Dynomax direct replacement Corvette mufflers in the past on both BB and SBC Vettes and one Vette ran 12's (72 LS-5 coupe) with the Dyno Max system on it. This was way back in the 80's seems like a long time ago right now
Exhaust gasses at the manifold are upwards of 1000 deg F. Heat wants to expand gas, so that's why there is a lot of pressure at that point. By the time it gets to the tail end of the exhaust system, it is between 100-200 deg. F. Cooler gasses compress, causing the pressure to drop [in the same size chamber]. So, the 2-1/2 inch exhaust outlet is NOT the bottleneck in the exhaust system. Putting a 3 inch exhaust tip on a 2" exhaust manifold system is a waste of time.
So you're saying I wasted a bunch of my time doing this....
If you want to change your mufflers and find some with the 2 1/2" outlets then you can buy the tips from Gibson with the 2 1/2" pipes. I did this on my Magnaflow system.
