I've been trying to stop a rear pinion seal leak on my 1971 Vette. I put one seal in today, still leaked and I'm in the process of replacing that seal one more time. I've done a few of the seals before, seems to be pretty straight forward. What am I missing or at there any tricks to prevent this from happening again?
It could be leaking from the splines of the yoke. Some guys put a little sealer on the splines while putting the yoke on to stop the leak. Also look at the yoke while it is off. Is the area where the seal rides in good shape or is it rough or a deep groove.
Measure the depth area in the case where the pinion seal sits. Then measure the pinion seal. If the seal measurement is greater than the case don't dirve the seal all the way. If you do the seal will distort causing it to leak
I am alos trying to replace pinion seal on my '82. Does the seal come off from the outside the differential case or inside? Once I removed the yolk I thought the seal would just come off it did not, Should I pry it off? Thanks
Look at the yoke where the seal rides. If there's a groove, you'll need a speedi-sleeve, or have the yoke sleeved.
Pack the cavity in the back of the seal with grease- there's a little spring around the OD of the seal. If it pops off when you drive the new seal in, there's nothing to hold the lip around the yoke.
Permatex fix my leaky splines!!! Check the drips path very closely with a flashlight as it is hard to pinpoint. I the drip originates around the pinion nut ---then you gotta easy fix. Coat the splines and off you go.
The yoke could have a worn spot (ring) in it or could there be to much fluid in the rear... just throwing things out.
If you really want to make sure of where the leak is coming from you can put dye in the oil and black light it.
We had a rear end cover one time that was defective. It had a porous hole in the casting and this hole ran right in to one of the cover bolt holes. We pulled the cover, re-sealed it, pulled it again and re-sealed it... It still leaked. Finally we went to the dye and used the black light to find the exact source of our leak.
I have detailed instructions on how to replace the front pinion seal on the web site. They are for 63-79, but there is no difference in the method for 1980-1982. A little different in getting to the pinion nut, but it should be enough info to get you through. http://willcoxcorvette.com/repairand...lp.php?hID=205
