Cruise control power
Old Nov 3, 2010 | 12:47 AM
Grumpy 427's Avatar
Grumpy 427
Default Cruise control power
Where does the cruise get its power from?
Old Nov 3, 2010 | 06:59 AM
7T1vette's Avatar
7T1vette
The "IGN" (ignition) system... You don't want the cruise to operate unless the engine is running. Best source is one of the IGN terminals in the fuse box; also put a properly sized fuse for the cruise control in that line.
Old Nov 3, 2010 | 07:43 AM
...Roger...'s Avatar
...Roger...
If your wiring is factory , the 20 amp "gauges" fuse supply's power to the brake switch then power goes to the cruise transducer. Hope that helps.
Old Nov 3, 2010 | 10:26 AM
Grumpy 427's Avatar
Grumpy 427
yes it does thank you.
To Cruise control power
