Ecklers Electric Headlights
Old Nov 4, 2010 | 01:05 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Ecklers Electric Headlights
Thinking about this electric headlight setup from Ecklers:
http://www.ecklers.com/corvette-head...l?dept_id=1381
Anyone have it installed or any comments. I have no vacuum to open or close the lights anymore since I hooked up a new charcoal canister, best thing I have done in a long time too, Vette doesn't stink anymore.
Old Nov 4, 2010 | 01:16 PM
MrJlr's Avatar
MrJlr
Old Nov 4, 2010 | 02:12 PM
SteveG75's Avatar
SteveG75
Lot of money. You could see if McSpeed still has some Killer Lights brackets available. Total cost for that even with new parts is about $600, cheaper if you get used motors.
One note is that with the linear actuators, there is no manual mode if you have an actuator failure.
Old Nov 4, 2010 | 03:09 PM
fauxrs's Avatar
fauxrs
Dangit!!!! I had put together sketches some time back about using linear actuators to do this job some time back - believe me the parts can be had significantly cheaper than their selling price - the actuators for this use probably can be had for between 50-100.
The only hard part (if your not an electrician) is putting together the relay system to signal the up/dn stroke of the actuator.
will have to see if I still have all that stuff.
Old Nov 4, 2010 | 03:18 PM
ylose's Avatar
ylose
hrm....mcspeed web is down.
GM performance sellls the MCspeed Complete kit too, there was link from their website to it.
I have the MCspeed kit, but never got around to getting all the components. Always figured I might bite the bullet and buy the completed one.
Old Nov 4, 2010 | 03:20 PM
Mashman's Avatar
Mashman
Why would hooking up a new charcoal canister cause you to no longer have vacuum?
Old Nov 4, 2010 | 03:49 PM
SteveG75's Avatar
SteveG75
GM Parts direct does not have the brackets. Chris at McSpeed was the only source of those.
Oops, read that you have the brackets already. I just got on the McSpeed site.
Here is the GMParts link for the kit with the C4 switch and module:
http://www.gmpartsdirect.com/results...rtnumber=pkit1
Alternate kit with Firebird module:
http://www.gmpartsdirect.com/results...rtnumber=pkit2
Old Nov 4, 2010 | 04:11 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You could repair the stock vacuum system and have it operable for way less than the price of that kit.
Old Nov 4, 2010 | 04:29 PM
...Roger...'s Avatar
...Roger...
Dang thats alot of money. How much is a vacuum pump ?
Has anyone tried an add on compressor and then using pressure rather than vacuum to move the actuators ?
Old Nov 4, 2010 | 04:34 PM
MotorHead's Avatar
MotorHead
I have a 600HP small block with over 250 duration cam. So there isn't much vacuum to begin with. I have all new hoses, redid the whole headlights last year. I have hydroboost brakes so I am running only headlights and a PCV system and that is all the vacuum I have can handle.
The addition of the charcoal canister was enough of burden on the poor vacuum I had ( the charcoal canister has a vent ) that now the headlights don't work.
I don't feel like piecing together a system and would like something that has every part I need. I have seen the McSpeed headlights in action and it is a pretty slick deal
Old Nov 4, 2010 | 04:45 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Thats A LOT of money for a couple of 6" electric actuators and some wires and relays. You can make a forune in no time if you buy the parts and sell that kit yourself for that much money.
Old Nov 4, 2010 | 05:04 PM
...Roger...
I haven't tried it but I would think you could install a vacuum pump and isolate the headlights from the engine vacuum.
The stock system if tight will operate on 5".
This isn't the cheapest.
http://cgi.ebay.com/ebaymotors/HOTRO...Q5fAccessories
Old Nov 4, 2010 | 05:11 PM
MotorHead's Avatar
MotorHead
I might think about am electric vacuum pump. I don't know anyone who has installed one or had success with one but since it will not be used to operate the brakes I should probably look into it.
If anyone knows a good type of pump for this application it would be appreciated
I wonder who Ecklers gets the kits from ?
Old Nov 4, 2010 | 05:31 PM
...Roger...
Here's one from Summit,looks like the one I posted above but less money.
http://www.summitracing.com/parts/SUM-760150/
Old Nov 4, 2010 | 08:18 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
I agree that the electrically operated headlights are cool....but the price!
An electric vacuum pump is a much cheaper solution. The Summit unit is the same unit sold by a Canadian company called CVR. They are in Ontario. You might be able to get it cheaper direct from them.
http://www.cvrproducts.com/vacuum_pump.html
A friend of mine has been using the CVR unit for years with no problems.
How do you have your charcoal canister hooked up? I only ask because it shouldn't change the way your exhaust smells, it's purpose is to collect, store, and then release gas vapors from the gas tank to then be burned by the engine.
Old Nov 4, 2010 | 08:32 PM
MotorHead's Avatar
MotorHead
My exhaust still smells the same, it is normal. My canister was never hooked up and vapors from the tank stunk up my garage. All I know is I bought a older model canister with only a inlet port from the tank and an outlet port to my PCV and now my garage doesn't stink anymore
I don't think I need a vacuum pump as elaborate as the CVR pump, that keeps the vacuum up all the time. I just need a simple one that can be hooked directly to the headlight hoses
Old Nov 4, 2010 | 08:49 PM
7t2vette's Avatar
7t2vette
Ah, that makes sense with the canister now.
As for the pump, it only turns on when the vacumm drops below 15 in. If you use it only for the headlights, and you use a vacuum reservoir and a good one-way check valve, it will hardly ever come on.
Another choice:
http://www.ssbrakes.com/commerce/det....cfm?nPID=6791
I've also heard of people converting 12v tire pumps into vacuum pumps.
http://www.instructables.com/id/conv...ressor-into-a/
To Ecklers Electric Headlights
Old Nov 4, 2010 | 09:05 PM
...Roger...
You could use both the engine and small pump,do you still have a tank ?
Old Nov 5, 2010 | 09:21 AM
Trae1976's Avatar
Trae1976
Motorhead, I sent you a PM.
Old Nov 5, 2010 | 11:18 AM
MotorHead's Avatar
MotorHead
Yes I still have the coffee can I fixed it last year so it doesn't leak. I make no where near 15 in of vacuum so these pumps would be on all the time. They are mainly a solution for power brakes. I just need something small and cheap to open and close my headlights.
My system probably still isn't perfect and most likely still leaks a bit. The addition of the canister made what vacuum I had not enough to open and close the lights. The canister has a vent and that creates a leak in the system. I plugged the vent and the motor ran like crap but the lights worked So I unplugged the vent.
Trae1976 sent you a PM
