taking the paint off
Old Nov 4, 2010 | 06:24 PM
377's Avatar
377
Default taking the paint off
i want to use paint stripper. what do u guys use. my car has 2 coats of paint on it and some body work under it. the seams are still good.its getting cold soon no heat in the garage.thanks
Old Nov 4, 2010 | 06:30 PM
PUNISHER VETTE's Avatar
PUNISHER VETTE
Old Nov 4, 2010 | 06:34 PM
MakoShark72's Avatar
MakoShark72
Razor blades!!! Thats what I used anyway. Heard too many horror stories about stripper, but guys use it so it must be safe. Do a search, there's lots threads on it.
Old Nov 4, 2010 | 06:37 PM
milo30's Avatar
milo30
I used stripper but it is messy and smelly. I don't think that I could finish it using razor blades. I get bored too soon.
Old Nov 4, 2010 | 06:43 PM
377's Avatar
377
how hard is it to do that way. how did u doit. how long did it take thanks
Old Nov 4, 2010 | 08:33 PM
78anniversary's Avatar
78anniversary
I used Capt'n Lee's Spra-strip. Available from corvette central. Had great luck with it.
Old Nov 4, 2010 | 08:58 PM
oldsarge's Avatar
oldsarge
I used razor blades, always keep them sharp, throw them away frequently and use new ones quit often. I have also used Capt. Lees, works great, just have lots of water with you and rinse often to neutralise the chemical reaction, remember to just do small areas at a time, and you will have great sucess!!!
Old Nov 4, 2010 | 09:09 PM
C3 4ME's Avatar
C3 4ME
I also used Capt'n Lee's. 5 years after the car was painted, I've had no problems with the paint from using the stripper. Just be sure to follow the directions as far as neutralizing the stripper after it's done it's work and you too won't have any problems. I would recommend it to anyone asking.
Old Nov 5, 2010 | 12:21 PM
TopGunn's Avatar
TopGunn
I used razor blades and highly recommend it. I was afraid of the nicks at first but in about 10 minutes you get the hang of it. I also recommend using a heat gun just ahead of the razor blade to warm up the paint, it releases MUCH MUCH easier and quicker. I did my hood in about 20 minutes right down to bare material, when you're done you can just vacuum up the paint shavings. Stripper is a mess!! I tried it on a spot near the vents on the fenders just to see how it worked. I was much happier with the razor blade method.
Old Nov 5, 2010 | 12:59 PM
u2bdet's Avatar
u2bdet
Default Razor blades!!!
I used razor blades to strip my 81 ...get a box (100) and some good holders of various sizes, I also used a heat gun on low ...at a distance to soften up the paint , take your time and ENJOY it ( I used my 2 kids as slave labor....if they wanna borrow the vette they gotta help!!) Its not that long a deal and you will know your car intimately !!
And never have to worry " Did I get all the stripper off ???"
Good Luck.
Neal
Old Nov 5, 2010 | 01:56 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Any fiberglass compatible stripper will work.
Old Nov 5, 2010 | 02:23 PM
DEEPSEA70's Avatar
DEEPSEA70
I used razor blades. Lots of sharp ones. A couple of beers dont hurt either.
Old Nov 5, 2010 | 02:56 PM
bashcraft's Avatar
bashcraft
So what are we looking at here, one beer per razor blade?
I just want to be prepared for when I start stripping mine.
Old Nov 5, 2010 | 03:13 PM
dochorsepower's Avatar
dochorsepower
I used the special stripper for Corvettes. Brush it on, sqeegee it off and wash with lacquer thinner. Did it in a weekend.
Old Nov 5, 2010 | 09:48 PM
Alex/plus's Avatar
Alex/plus
And....what is the name of the special stripper for Corvettes?
Old Nov 6, 2010 | 02:13 PM
377's Avatar
377
thanks for the info
Old Nov 6, 2010 | 03:07 PM
orourke's Avatar
orourke
I find it quicker and a lot more fun to strip with razor blades. A lot cheaper too. Wear safety glasses. Paint will be flying everywhere once you get the hang of it.
Marty.
To taking the paint off
Old Nov 6, 2010 | 07:07 PM
upcominZ's Avatar
upcominZ
Didn't know about the razor method. Going to try it soon, car needs paint.
Old Nov 7, 2010 | 01:01 AM
John 65's Avatar
John 65
Hey Mark, I wish I saw your thread sooner. I am in the same town as you and just finished stripping my friends 69 for him this morning. I used the chemicals on it, Capt'n Lee's and on my 68 this past summer and a 65 I used to own. Never had any problems with it. Bring that 73 around !
Old Nov 7, 2010 | 08:17 AM
sweeet76's Avatar
sweeet76
How long does it take after all emblems, etc are removed from the car to strip it? I know door jams and tight areas will take the longest.
