Fuel Pump
Old Nov 6, 2010 | 10:56 AM
presasa's Avatar
presasa
Default Fuel Pump
I am working on wakening up the engine on my 79 (intake, carb, headers) and would like to replace the fuel pump with a performance one and also dress up the engine . Most aftermarket pumps do not have the return line. Can I do away with stock pump and replace the gas cap with a vented cap??
thank you in advance for your help
AP
Old Nov 6, 2010 | 11:41 AM
Mike Ward's Avatar
Mike Ward
You can do whatever you want, but downgrading the car to a non-return pump is not a bright idea.
Pump type has no connection with vented/non-vented caps either.
Old Nov 6, 2010 | 11:16 PM
presasa's Avatar
presasa
I respect your response but "not a bright idea" is not a bright answer.
Old Nov 7, 2010 | 09:59 AM
BKbroiler's Avatar
BKbroiler
I agree that the stock pump is not the prettiest, but they are, by far, your best option if you intend to drive the car. The return line will prevent vapor lock, the pump output does not require a regulator, and its capactity is adequate for 500 HP.
Old Nov 8, 2010 | 08:49 AM
Mike Ward's Avatar
Mike Ward
BK has outlined why downgrading to two line pump is not good from a functional point of view and how a shiny one is unnecessary and wasted money from a performance point of view.
The presence of 2 or 3 lines on a pump has no relationship to having a vented or non vented gas cap. The air entering the gas tank to replace the fuel used is routed by the charcoal canister in the drivers side wheel well.
Old Nov 8, 2010 | 09:00 AM
...Roger...'s Avatar
...Roger...
I agree with the comments above.
Presasa did you ever get your headlight issues resolved ?
Old Nov 8, 2010 | 10:26 PM
presasa's Avatar
presasa
Default Pump - Lights - Carb
I really appreciate everyones response, I just needed to understand the full function of the return line. I will keep the original pump.
As far as the lights, I believe it was a loose vacuum line
Can I get your imput on carb, I am replacing the intake with the Eldebrock performer - my thoughts were to use a Holley 600 cfm -
The original Qj was bad so I replaced it with a Qj that i took off a truck. Rebuild it myself and works extremely well, excellent response. I have both a Holley and a Qj on the workbench just need to decide which carb to use now. I appreciate any response.
AP
Old Nov 8, 2010 | 11:51 PM
Mike Ward's Avatar
Mike Ward
You will gain nothing with the Holley unit. Save your money.
Old Nov 9, 2010 | 07:24 AM
7T1vette's Avatar
7T1vette
The Q-Jet has 750 cfm capability and flow determined by engine demand. Why dump all that for a puny Holley?
To Fuel Pump
