Tachometer problems
Old Apr 4, 2002 | 05:10 AM
A78Corvette's Avatar
A78Corvette
Default Tachometer problems
I bought a 79 recently. The tach did't work when i bought it. The other day it starts working messed up. Idling at 3500 and if you just touched the gas it pegged it. I don't know much about wiring where do i start looking for the problem? Is there a link that would help? Thanks in advance. :conehead
Old Apr 4, 2002 | 07:39 AM
Dalannex's Avatar
Dalannex
Default Re: Tachometer problems (A78Corvette)
I'm no expert either, but I understand from conversation here that they have a circuit board on back that goes south and needs replacement once in awhile. Not sure, just remember seeing that.
Old Apr 4, 2002 | 10:15 AM
bl75vette's Avatar
bl75vette
Default Re: Tachometer problems (Dalannex)
Mine did not work at all. Stuck at 1500 RPM's. While redoing the interior, I pulled the dash panel out and removed the speedo and tach. I found the circuit board fried. I replace the board and ran a 12V current to it and reset the needle and it now works just fine. It you remove the tach, be sure to drop the steering column or else you will crack the pad on removal.
Old Apr 4, 2002 | 03:08 PM
kgraumann's Avatar
kgraumann
Well, my tach was not working when I bought my care as well. It would try to work, but never really worked correctly.
I replaced the Tach Circuit Board in the Instrument Cluster, and it solved all my problems. I did some research on this, and the tach for 78-82 was having burnout problems, and this was a common problem.
I bought my replacement through Ecklers for 69.00 or so. But I think the other vendors had them as well.
http://www.ecklers.com http://www.corvettecentral.com http://www.corvetteamerica.com
I don't think anybody else sold this to my knowledge.
Old Apr 4, 2002 | 03:43 PM
razz1980's Avatar
razz1980
Default Re: Tachometer problems (kgraumann)
just ordered mine last week from ecklers for $59.95..the circuit board is the culprit 95% of the time..lol
To Tachometer problems
