Rattle from underneath off throttle
Old Nov 8, 2010 | 11:06 AM
75+78 Corvettes's Avatar
75+78 Corvettes
Default Rattle from underneath off throttle
On my 78 L82 4speed whenever I'm driving and let off the throttle I hear a rattle that sounds like its coming from the passenger side underneath the car. As soon as I press the gas a little the sound goes away. It seems to only happen when driving. It does not matter what gear or speed I'm going and it does not change tone.
It's been bugging me since I got the car earlier this year but am figuring out what all repairs I can do this winter.
Old Nov 8, 2010 | 01:12 PM
wcsinx's Avatar
wcsinx
Prob. an exhaust hanger
Old Nov 8, 2010 | 01:55 PM
phildawg19's Avatar
phildawg19
yeah its going to be something to do with your exhaust. clamp is probably loose or you might not have one
Old Nov 8, 2010 | 02:23 PM
7T1vette's Avatar
7T1vette
Exhaust system, heat riser valve (passenger side) spring broken, transmission linkage rattling (if 4-speed). Those are the "Big 3" to check out....
Old Nov 8, 2010 | 03:09 PM
dochorsepower's Avatar
dochorsepower
Also check catalytic converter core. Happened to me recently with aftermarket unit.
Old Nov 8, 2010 | 04:24 PM
Will's'74VetteL-82's Avatar
Will's'74VetteL-82
Sometimes a piece will break off and get stuck, and rattle in the cat at certain rpm frequencies.
Also check all of the above advice.
Will
Old Nov 8, 2010 | 05:06 PM
7T1vette's Avatar
7T1vette
Years ago, my brother had a 'cat' in his car...it was sleeping on the warm engine. Not pretty when he started the car... [it didn't 'rattle', though...]
Old Nov 9, 2010 | 07:06 AM
ED79's Avatar
ED79
Also check the heat sheild that's around the cat mine would vibrate. Ed
Old Nov 9, 2010 | 02:56 PM
75+78 Corvettes
Thanks. I'll check them all out. The car's all original so something may have come loose in 30 something years.
Old Nov 9, 2010 | 04:48 PM
mj9311's Avatar
mj9311
same thing happened to a buddy of mine... cant imagine it being pretty
To Rattle from underneath off throttle
