454 Cooling
Old Nov 12, 2010 | 07:28 PM
sjr1971's Avatar
sjr1971
Originally Posted by Babypig
Hi,i live in smithtown, you could call me on my office phone ,i have a 70 ls5 vert that i cooled down the right way without baloney fans, something is wrong if you need fans, the general didn't send them out for sale with 'em. you can call me at 631-651-2721.
I agree. My BB began to run high. I pulled the lower hose and a bunch of water came out . I pulled the upper hose to replace the thermo and check the upper hose. I had standing water in the upper radiator throat. R&R'd the rad to a radiator shop. Many plugged core tubes; had the core replaced. The 454 runs 190 degrees on the hottest days. It will go to 200 when stressed but return to 190 when idling. [stock Winston radiator]
Old Nov 12, 2010 | 07:40 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Originally Posted by thoyer
What you are describing is exactly what I experienced with mine. I had a leak, had it fixed, flushed, cleaned and it still ran hot. I did everything before going the Dewitts route, timing, thermostat, fan clutch, seals, carb jetting, you name it. Unless you are having the car judged, you'd be hard pressed to tell the difference between the radiators.
After installation I put the original radiator back in the Dewitts box and stored it away so that if, or when, I ever sell the car, the original radiator goes along with it.
Tom
Exactly the same story with me. I had Dewitts paint the aluminum radiator black and I assembled the entire package, support and shroud, on the bench with new Dr. Rebuild seals. The new caretaker will receive the old radiator in the Dewitts box. Meanwhile, I get to enjoy driving a cool big block in the Florida heat for many years to come!
Old Nov 13, 2010 | 08:46 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Another thumb up for Dewitt's radiator, installed it 3 years ago and never looked back.
