What gives here
Old Nov 10, 2010 | 04:09 PM
Jackk's Avatar
Jackk
Default What gives here
Hi everyone, I have the steering column out of my 71 to replace the rag joint. I purchased a Dorman 31011 unit to put in, but it does not want to go on the input shaft on the steering box. According to the supplier it should fit everything from 69 up. It looks like the spline is a little coarser on the new joint. Are there different splines on some boxes?
Jack
Old Nov 10, 2010 | 04:38 PM
MelWff's Avatar
MelWff
according to this it should fit, maybe somebody changed the steering box or the wrong part was in the box
http://www.summitracing.com/parts/RN...del%7cCORVETTE
Old Nov 10, 2010 | 04:44 PM
Jackk's Avatar
Jackk
I can't be sure if the box has been changed, but it sure looks original. It has the flat on one side. I thought all the boxes had the same spline.
Old Nov 10, 2010 | 04:54 PM
MelWff's Avatar
MelWff
they should have the same spline but maybe you were given the wrong rag joint see if they have another and compare it
Old Nov 10, 2010 | 05:12 PM
Jackk's Avatar
Jackk
I wish I could, but they ordered this one in for me. I will return it and try again.
Thanks Jack
Old Nov 10, 2010 | 07:12 PM
72LS1Vette's Avatar
72LS1Vette
The rag joint is a pretty important part of the steering system. I'd spend the extra $ and get a genuine GM part from one of the forum vendors.
Rick B.
To What gives here
