EGR Vacuum Ported Valve Switch
Old Nov 10, 2010 | 08:53 PM
80blackbeauty's Avatar
80blackbeauty
7th Gear
Default EGR Vacuum Ported Valve Switch
I purchased my first Vette, and am doing some work on her. I am trying to figure this out. My EGR Vacuum Ported Valve Switch has to vacuum connections (which I have connected), but then i have an electrical port that is broken off. What wire is connected to this port?
Old Nov 11, 2010 | 11:32 AM
MelWff's Avatar
MelWff
Are you sure it's for the EGR? Could you be referring to this part?
http://www.ecklers.com/corvette-efe-...1980-1981.html
Old Nov 11, 2010 | 12:00 PM
80blackbeauty
7th Gear
Yes, that's the part. What wire goes to that terminal.
Old Nov 11, 2010 | 01:25 PM
MelWff's Avatar
MelWff
Looking at the picture of the part and the diagram on the website, are you sure that's an electrical connection? In the photo it looks like a vent with a small filter in it. Maybe someone else will chime in that is more familiar with the part
Old Nov 11, 2010 | 04:38 PM
Rich's'78's Avatar
Rich's'78
yes,it has a vent so when the temp reaches the set-point, it moves and and vents the otherwise sealed system for the EFE valve (not wanted on hot engine). Not EGR.
Old Nov 11, 2010 | 06:41 PM
80blackbeauty
7th Gear
thank you for the reply, that is good to know. Should i have a vacuum reading from either of the 2 hoses coming off of this?
I tried taking a reading, with no luck.
Old Nov 11, 2010 | 09:46 PM
Rich's'78's Avatar
Rich's'78
it should match manifold vac when stone cold. when hot, one port should match manifold vac and the other should read zero. that is only if it is for the EFE system. I believe it is for the vacuum advance system! It locks in full advance until the engine is hot and then lets the advance work as it should when hot. get a book.
To EGR Vacuum Ported Valve Switch
