Trailing arm shimming
Old Nov 11, 2010 | 01:47 AM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
Default Trailing arm shimming
When starting with no shims at all, I guess I would start with TA bushing in center of pivot bolt and shim equally on each side? Should I torque pivot bolt with spring and strut rods removed to assure free movement of TA? Any opinions or tips would be appreciated.
Old Nov 11, 2010 | 08:35 AM
Timsride's Avatar
Timsride
I shimed mine after the whole rear of the car was back together. Somewhere on here is a thread on how to align car. I shimed the rear wheels while setting camber as well. I ran strings down side of car front to back and the front of rear tire touches string and the rear of the tire had a specific distance. The shims should be piled in there tight at that point. It is critical that the front of the rear wheel points outward slightly as under load it will pull in. You do not want toe in on rear or You wont be able to steer car under hard acceleration.
Old Nov 11, 2010 | 09:07 AM
Mick71's Avatar
Mick71
Thanks for reply. I'll need to find that thread because I'm starting from scratch after frameoff and need to get wheels at least in the ballpark to drive the 25 mi. to the alignment shop. Yeah, I should have kept record of the shims that came out.....
Old Nov 11, 2010 | 12:42 PM
69autoXr's Avatar
69autoXr
NO, you want toe IN at the rear, not toe out.
Old Nov 11, 2010 | 12:47 PM
7t3shark's Avatar
7t3shark
And a little negative camber.
Old Nov 11, 2010 | 09:47 PM
Mick71's Avatar
Mick71
Okay, so I need to shim so the front of rear tires are toed in, correct? Negative camber would be the top of the tire will be in further than the bottom as adjusted with strut rod,right? Toein for driveline torque, neg. camber for lateral load?
Old Nov 11, 2010 | 11:15 PM
wcsinx's Avatar
wcsinx
uhm
no
You want about 1/8" rear toe-in with the car at it's normal ride height. The wheels will want to go more toe-out as the trailing arm moves up (or simply outside of level).
Old Nov 11, 2010 | 11:16 PM
wcsinx's Avatar
wcsinx
http://www.duntovmotors.com/tech-alignment.php
Old Nov 11, 2010 | 11:33 PM
Mick71's Avatar
Mick71
Thank you!!! That is exactly the info needed. Starting on that tomorrow, so you just saved me alot of trial and error.
Old Nov 12, 2010 | 08:57 AM
Timsride's Avatar
Timsride
Sorry about the toe I was just trying to give an idea of the link from memory. There is another good thread from a guy on here who sets his own alignment in his garage. Just make sure You have the shims firmly in place.
Old Nov 12, 2010 | 09:20 AM
Mick71's Avatar
Mick71
No problem. Thanks for input.
Old Nov 12, 2010 | 10:56 PM
Mick71's Avatar
Mick71
I followed Duntov procedure and all is well. It will definitetly get me to the shop now. One more item checked off the list. Thanks to all. If we weren't in cyberspace I'd buy beers all around
Old Nov 14, 2010 | 12:57 AM
wcsinx's Avatar
wcsinx
Glad it worked out for ya.
Just one note though. I wouldn't bother taking it to a shop for an alignment unless it's one that specializes in Corvettes. Most techs and/or grease monkeys are going to go cross-eyed looking at the C3's rear. I have done my own alignments for years now using nothing but strings, an angle finder, straight edges, and a dial caliper. And everytime I've had it cross referenced with modern equipment, my alignments have been spot on.
Old Nov 14, 2010 | 12:15 PM
Mick71's Avatar
Mick71
Luckily there is an old alignment shop about 25 miles from me. The same guy has been doing business there forever and eager to do it. He said it's been a long time since a c2 or c3 had been there. He actually had rear TA shims. Thanks again
Old Nov 14, 2010 | 05:29 PM
Jack Wood's Avatar
Jack Wood
Default Any info on string alignments for the front?
Any info on string alignments for the front? I just want to get it close enough for 1000 miles a year.
Old Nov 15, 2010 | 08:09 AM
Mick71's Avatar
Mick71
It's actually kinda easy, just take your time and make sure the car is level. I followed the Duntov procedure from the link above and worked well to get all four wheels really close.
Old Nov 15, 2010 | 08:38 AM
wcsinx's Avatar
wcsinx
Yeah, it's the same basic logic. The front is actually much easier. Toe is adjusted via the tie rods. Adjust both sides evenly and shoot for 0 toe. Camber is adjusted with shims inserted between the frame and the top a-arm cross shaft. It depends a lot on how you drive, but 1/2° negative camber will get you down the road just fine.
Castor I don't mess with.
To Trailing arm shimming
