Wheel alignment required?
Old Nov 13, 2010 | 02:20 AM
zogenoto's Avatar
zogenoto
4th Gear
Default Wheel alignment required?
Just completed a front suspension rebuild...control arm bushings, ball joints, tie-rods, wheel bearings, etc. I replaced the same amount of new shims on the upper control arms and repositioned the tie-rods length using caliper dividers. Wheel alignment still required? Have anyone done a rebuild w/o doing a subsequent alignment? Thanks...
Old Nov 13, 2010 | 04:23 AM
dgood's Avatar
dgood
zogenoto,
I did the same thing to mine last year, including shocks and springs and did not get an alingment done. It handles 100% better! It feels fine, drives straight and seems ok. I have only put about 1000 miles on it since so I can't tell if there is irregular tire wear or not.
Old Nov 13, 2010 | 07:13 AM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
I'm a firm believer that any time you do major suspension work, you need to get an alignment. It's a lot cheaper than tires.
Old Nov 13, 2010 | 09:55 AM
7T1vette's Avatar
7T1vette
Suspension parts can be exchanged, but pieces are not exactly the same. Alignment is the final 'fine tuning' of the suspension so that all is correct. Any time a change is made to critical suspension parts, a wheel alignment is in order.
Old Nov 13, 2010 | 03:30 PM
biaggio's Avatar
biaggio
I have an 82. Just had some front end work done. They spent 2 hours doing just the alignment on the front and abck. Old school mechanics. Car drives great!!! Highly recommend it.
Old Nov 13, 2010 | 03:41 PM
straub18045's Avatar
straub18045
yes very much required or you will chew the tires off quick
Old Nov 13, 2010 | 04:04 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Absolutely yes. If not, you will be buying new tires in a short while! You spent all that time and money rebuilding, now go get the alignment done.
Old Nov 14, 2010 | 08:15 PM
tomgallucci57's Avatar
tomgallucci57
i just did my front end also ,and on the first drive around the block there was a major difference in the steering wheel feel,,nothing like it felt before,,it felt numb,and the wheel didnt return on its own after turning a corner,,,tightened everything to spec.,,,ill be going to the alighmnt shop hopefully tommorrow,,,best of luck...ps also did the rear strut rods.
Old Nov 14, 2010 | 08:19 PM
tomgallucci57
one more thing,what did you torque the relay rod to pitman nut to. 35 lbs -40 lbs.
Old Nov 14, 2010 | 10:59 PM
zogenoto's Avatar
zogenoto
4th Gear
Thanks to all...will be getting a wheel alignment later this week. Did not do any work on the steering side....pitman, idler, etc....just from the tie rods and forward.
To Wheel alignment required?
