Piston position to install the heads
Old Nov 13, 2010 | 03:35 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
Default Piston position to install the heads
It's time to put the heads back on the engine. To do this, I know I want to set the #1 cylinder to TDC. As I turn the engine over by hand, I watch the lifter for the intake valve go up, then come back down and then the piston is at the top of the cylinder and the timing mark is at 0. Is this the position I want the engine in to bolt the heads on and start tightening the valves down at?
Old Nov 13, 2010 | 03:46 PM
midyearvette's Avatar
midyearvette
you can bolt the heads on with the pistons in any position
to set the valves, follow the sticky on how to do it cold or when assembling the engine...hope this helps, good luck....
Old Nov 13, 2010 | 03:50 PM
gofastvette's Avatar
gofastvette
yes its easy to time the engine that way....check to see how the lifters stack up on # 1 and # 6, they both should be even with 6 a little higher than 1 or 1 a little lower...that indicates both valves closed on #1 and the damper lined up with the timing tab.
Old Nov 13, 2010 | 10:42 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
To set the engine to TDC firing (not overlap)...
First set #1 piston approximately near the top of its travel - don't need it exact because you will only need to know if the #3 intake lobe is up - how? - just look at its lifter. If it's up you're almost finished; if it's not, turn the crank another full turn until the #3 intake lifter is up.
Next, you will want to set exactly TDC. With the head still off, it's really easy to get #1 exactly to TDC even without a dial indicator by setting #3 and #5 pistons exactly the same distance down in their holes. Keep adjusting until they're exactly the same distance below deck. Now your exactly at TDC-firing on #1 (and TDC-overlap on #6)! Mark your balancer and/or timing tag for future reference!
Although this procedure is not required to bolt on the heads, it makes it a lot easier to know where the exact TDC position is, and whether the engine is at firing or overlap on #1.
Old Nov 14, 2010 | 11:59 AM
Jack Wood's Avatar
Jack Wood
Default Just loosen the rocker arms and bolt on the heads.
Then adjust the valves and worry about where the piston is for each cylinder. Or am I missing something here?
To Piston position to install the heads
