Gear Patern Pics
Old Nov 13, 2010 | 08:17 PM
'75's Avatar
'75
Default Gear Patern Pics
Used GM gears, .009" backlash. OK? or tweek it a little more?
Drive side
Coast side
Old Nov 13, 2010 | 09:31 PM
vettme's Avatar
vettme
I would go with it . Ive been there and your pattern looks pretty good for a used set. You could try to improve but its a give and take and the time isnt worth the effort or result and you will probably end up back where you started. Let it ride.
Old Nov 13, 2010 | 09:34 PM
7T1vette's Avatar
7T1vette
Was the gear set loaded at all...or just run together 'as is'? Once the gear set is under load (in the vehicle), the wear pattern will be in a different location than with 'no load'.
Old Nov 13, 2010 | 09:44 PM
'75's Avatar
'75
To check the patern I held a prybar against the carrier next to the ring gear and put tension while I rotated the pinion.
Old Nov 14, 2010 | 05:18 PM
'75's Avatar
'75
ttt
Old Nov 14, 2010 | 10:14 PM
7T1vette's Avatar
7T1vette
Looks pretty good to me...
To Gear Patern Pics
