79 gauge circuit board help needed
Old Nov 14, 2010 | 04:19 PM
C3Dave's Avatar
C3Dave
Default 79 gauge circuit board help needed
My gauges werent working so I pulled the gauge cluster out and found the wiring harness plug was only half plugged in. I can see some of the tabs on the cb were broken off. Im going to order a new cb. My question is about the open holes on the back. Should there be a light socket in each of the 3 open areas? Does it matter what color socket goes in each hole? I also see just to the right of where the plug goes in, theres a nut missing. Will I need to get a new one when I install the new cb? I just wanted to figure out what all I will need to order besides the cb. TIA......Dave
Old Nov 14, 2010 | 04:48 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
you have all the nuts in the right place. Looks like you just need to replace the printed circuit.
The housing show below has the low fuel warning module in it, and you have a bulb.. (upper left hand corner)... you should remove this bulb socket and place it in the one below where you are missing one. If you leave it where you have it the light will stay on all the time. In the two on the right hand side in the picture.. yes.. these need to be bulbs and not open holes.
Here is a link the printed circuit on the forum special section of the site too!
http://willcoxcorvette.com/advanced_...php?cPath=2059
Old Nov 14, 2010 | 04:51 PM
0Willcox Corvette
Former Vendor
Here is another picture of the printed circuit... it has all the circuits mapped out for testing.
Old Nov 14, 2010 | 06:11 PM
C3Dave's Avatar
C3Dave
Thank you for the info and diagrams Willcox. I will order the circuit board from you tonight. Do you stock the 2 bulb sockets that I need?
Old Nov 15, 2010 | 10:21 AM
0Willcox Corvette
Former Vendor
http://willcoxcorvette.com/product_i...ducts_id=25914
We have them.. they are 5.90 each.. if you need them added, call sales at 800-588-3883 and/or send Tommy an email at willcox@willcoxcorvette.com.
post here too.. I'll be checking in off and on.
Willcox
Old Nov 15, 2010 | 10:45 AM
C3Dave's Avatar
C3Dave
I called customer service and spoke with Norm who added the sockets to my order. Thanks again for your help.
Old Nov 15, 2010 | 04:12 PM
0Willcox Corvette
Former Vendor
No Problem and thank you for the order!
Willcox
Old Nov 15, 2010 | 10:09 PM
Oldguard 7's Avatar
Oldguard 7
You have a picture for the speedo/tach circuit board like the ones you posted on this thread.
Old Nov 15, 2010 | 10:18 PM
...Roger...'s Avatar
...Roger...
It might be here.
http://willcoxcorvette.com/advanced_...p?category=RIH
Old Nov 16, 2010 | 06:32 PM
0Willcox Corvette
Former Vendor
Don't know if I do or not Sarge... Let me check.. brb..
Old Nov 16, 2010 | 06:36 PM
0Willcox Corvette
Former Vendor
Nothing is traced out on the circuit like the one above, but with these pictures figuring it out should be a snap. If not... Post again. I'll be here
Old Nov 16, 2010 | 09:47 PM
Oldguard 7's Avatar
Oldguard 7
Thanx. I have no dash lights and when I pulled my instrument cluster, I also noticed that some of the thin copper "lines" were broken as well as the one of the ones where the connector fits into was folded over. I'm going to purchase another circuit board. I suspect I have a problem in the wiring but since the circuit board I have is in bad shape. Thanx again.
Old Nov 18, 2010 | 09:46 AM
0Willcox Corvette
Former Vendor
Sarge, here is the link to the circuit in the forum sale section. http://willcoxcorvette.com/product_i...ducts_id=25310
Old Aug 5, 2022 | 02:43 PM
JohnnysRed79's Avatar
JohnnysRed79
7th Gear
Does anyone have a picture of the 79 C3 circuit board installation. I am not sure if I have all of the nuts in the right place.
Old Aug 5, 2022 | 02:50 PM
JohnnysRed79
7th Gear
I think I may have damaged my oil pressure and voltmeter gages when I installed my new circuit board on my 79 C3.
Old Aug 5, 2022 | 03:07 PM
interpon's Avatar
interpon
you should post a new thread to your question, this one is very old.. but i do like the OP avatar.. wonder if updated
To 79 gauge circuit board help needed
