brake pad replace
Old Nov 15, 2010 | 01:18 PM
79c3man's Avatar
79c3man
Default brake pad replace
do I need a dual piston brake pad spreader to replace the brake pads on my 79 vette
Old Nov 15, 2010 | 01:24 PM
straub18045's Avatar
straub18045
no you can use a scissors type spreader, leaving old pads in then use the tool
Old Nov 15, 2010 | 01:25 PM
7T1vette's Avatar
7T1vette
You can change just pads without one, but it's a bit more trouble. Before you remove each pad (separately..one at a time), stick a good sized paint scraper or spatula blade between the back of the pad and the piston. Then push the piston back into its bore so there is enough room for the new pad. [Note: If your pads are very worn, you need to watch the level of the brake fluid in the master cylinder. As you press the piston into the bore, the brake fluid will 'back-fill' the M/C. You will have to remove some of the fluid to keep it from overflowing...unless you've never added any since the last brake job!]
Once the piston is pushed back, hold it ther while you remove the old pad and insert the new one. P.S. If you put any of the anti-squeal stuff on the back and edges of the new pads, do them all first and let them firm up before you begin the exchanging of pads.
Old Nov 16, 2010 | 07:17 AM
Aussie79's Avatar
Aussie79
Spreader? I had mine out yesterday (doing the parking brake shoes) and I just pushed them back with my hands, no tools needed.
Cheers, Dennis.
Old Nov 16, 2010 | 12:53 PM
79c3man's Avatar
79c3man
why is it when I push the back pad in the front pad moves out and vice -versa ,the pistons won't stay in
Old Nov 16, 2010 | 01:44 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Brake fluid displacement pressure. Corvette brake pads are in contact with the rotors at all times. The pistons are not supposed to stay in.
Get a couple of Caliper Clippers.
Old Nov 16, 2010 | 01:57 PM
7T1vette's Avatar
7T1vette
That's why you only remove one pad at a time...so that doesn't happen. If you remove the calipers, you will have to restrain all the 'free' pistons so they won't blow out of their bores.
To brake pad replace
