Master Cylinder Brake Lines
Old Nov 20, 2010 | 03:11 PM
Fastclient's Avatar
Fastclient
Default Master Cylinder Brake Lines
Doing some brake work and was going to replace the lines from the master cylinder to the switch. I notice the front line to the switch is 3/16" and the back line is 1/4" Is this correct or were they replaced with the incorrect size? Looked in the AIM but couldn't find anything on size tubing used. Thanks!
Old Nov 20, 2010 | 04:15 PM
Fastclient's Avatar
Fastclient
Failed to mention this brake question is in regards to my 1979, L82, manual trans
If someone could take a quick peek under their hood to see if theirs are different sizes (don't need to know specific sizes just if they are different) would be eternally grateful.
Old Nov 20, 2010 | 04:28 PM
Bob Heine's Avatar
Bob Heine
Yes, they are different size and my '72 has 3/16 on the front and 1/4 on the rear.
Old Nov 20, 2010 | 04:41 PM
Fastclient's Avatar
Fastclient
Thanks, now I can head back out to the garage and see how many kinks I can put in those new lines!!
Old Nov 20, 2010 | 04:58 PM
Bob Heine's Avatar
Bob Heine
I gave up and replaced my mess with pre-bent stainless lines. The set I bought came with all the correct color fittings (I didn't know -- mine were rust color) and the lines were wrapped with stainless coils like the originals. InlineTube.com sells the plain steel set for $125 and stainless for $150. It's an 8-piece set that includes everything but the tees.
I have successfully single-flared stainless tube with 37-degree flares for AN fittings but have yet to make a safe double flare.
Last edited by Bob Heine; Nov 20, 2010 at 04:59 PM. Reason: Spelling of company name
Old Nov 20, 2010 | 08:19 PM
dgood's Avatar
dgood
fast client, I just replaced all my lines over the last couple of weeks and mine were 3/16 and 1/4. I bought mine from ZIP (steel) all pre-bent and they fit right in. Replace the brake hoses while you are there. I bought a new master cylinder also while I was at it. all very easy! (my first time doing this)
Old Nov 26, 2010 | 06:29 PM
Fastclient's Avatar
Fastclient
Thanks for the replies everyone. Took the advice and bought the pre-bent lines from Corvette Specialties here in Mpls. Didn't exactly slip right in but after about an hour of tweaking got them to fit. Got to say it was way easier than starting from scratch then trying to double flair them. Now what to do, what to do with the new double flair tool I bought and the stick straight lines laying on the work bench.
Old Nov 26, 2010 | 08:21 PM
Bob Heine's Avatar
Bob Heine
Hmmm. Why not make yourself a couple of master cylinder bleeder pipes? It's good practice and you never know when you'll need to replace the master. Or, you can put them in the drawer like me. My drawer has quite a few rarely if ever used tools. Like my rebar tie swivel hook....
To Master Cylinder Brake Lines
