Power Steering valve internal wiev
Hi,
yesterday,I have done the rebuilt of PSV.
In the rebuild kit I have found a big "O-ring" but I don't find a palce to put it on.
Time ago I have bought another PSV for spare so I have decided to open it and I found this difference:
The left one is the old and was full of some liquid sealer everywhere
,the right is what I have put in the car.
In the left one appeare like someone have done a sort of honing work?
Wht do you think about this difference.
,the right is what I have put in the car.In the left one appeare like someone have done a sort of honing work?
Do a search in the archives (or send a PM to Jim_Shea) for Jim Shea's papers on power steering component rebuilding. There are good drawings and descriptions of what is needed to rebuild the control valve correctly. Having more information is always a good thing.
I think without Oring the valve leak all the time.
I don't have tested the right one,I'm waiting for the oil delivery.
I hope everithing work and no more leak,I have changed all hoses too.
I'll keep up posted.
Ok,I have a good news,the work is done !!!
I have replaced all the hoses,balanced the valve(I can move "frealy" the cylinder rod),and refilled the oil.
I have started the engine with the car on hoist no problem.
I have receck the oil level 3 times.
I don't jet drive the car for a road test.
I have followed many thread on this forum really helfull.
Before the test drive I need to check anything else?
Sometime after 1976 the control valve was changed. The o-ring groove was eliminated in the housing and a metal plate with a molded rubber gasket was incorporated into the design. At that time the o-ring groove was eliminated. I can't find the metal plate in any of my control valve assembly drawings up through 1976. And for some reason I don't seem to have any control valve drawings that are listed as 1977 or later.
Do the rebuild kits include both an o-ring as well as the metal plate with rubber gasket? Or do they only come with a metal plate and rubber gasket that is expected to service both kinds of control valve housings?
Yes, Fords and Mercuries did have a control valve type linkage booster power assist steering. I do not think that they purchased their valves from Saginaw Steering Gear, however.
Pippo350, do you mind if I use your photo of the two control valve housings in one of my papers?
Jim
Jim
In the rebuild kit I have found the two O-ring and the metal plate(thin) without gasket.
@ Jim after the valve is balanced (I can move the cylinder rod in and out with the hand)
I'm done?I can drive the car in safety?
Thank you !!!
Thank you !!!
Jim
Jim
After you have rebuilt the valve and placed it in the car, be very careful when you first start the engine. If the valve is not balanced, it can very rapidly power the steering all the way to full lock in one direction. This can cause the steering wheel to whip all the way to full lock as well. Several people have reported that they suffered bruises from being hit by the steering wheel spoke when their hand or arm was in the way.
There is a procedure for balancing the valve after it is installed in the car.
Jim
Jim
