Solid FT Camshaft recommendation BBC
Old Nov 24, 2010 | 02:58 AM
Simmo's Avatar
Simmo
Originally Posted by 427Hotrod
The dual plane is a good idea to help those heads and I'd consider adding the divider back in.
That Lunati would do well but I'd consider putting it on a 108 LSA to help those heads. It's not big enough to be too ratty on the street with a tight LSA. It's relatively small overall.
JIM
Do Lunati offer the option of changing the LSA I dont see it on the website. I think Jims idea of the 108 LSA would help. I'll also see if some divider can go back in.
Old Nov 24, 2010 | 08:49 AM
DRIVESHAFT's Avatar
DRIVESHAFT
If you call Lunati and talk to them you can get it ground with a 108 lsa.
Old Nov 24, 2010 | 09:01 AM
tt 383's Avatar
tt 383
Originally Posted by TheSkunkWorks
You're reminding me of the old mushroom cams I used to run in BB Buicks. You could run some outrageous ramps with those things. Hmmmm. Still have the tool for clearancing the block for them...
.842" .00705"/°
.874" .00733"/°
.904" .00759"/°
.960" .00808"/°
Yeah, I'll take an extra .00103 of valve lift per degree any day thankyou
Old Nov 24, 2010 | 09:22 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I have a buddy that has a complete mushroom cam setup for a BBC brand new sitting in his attic that he bought back in the late 70's. He bought two setups and built a killer 454 with it and did very well in the sneaky street race world in Kansas City area. He still has the other one sitting there. I'm trying to get my hands on it. I think it would be cool in my old 427!
Can you post a pic of the cutter tool that you have?
JIM
Old Nov 24, 2010 | 09:57 AM
iree75's Avatar
iree75
I just got my 75 back on the road this past weekend with a 060 over 427 running a comp magnum 11-218-4 (236/236 @ .050 .561/.561 110 lsa) and comps edm solid lifters, old 840 square port heads with stock valve sizes no porting. ~10.2 static compression. With a 373 gear it gets sideways if I roll into the throttle in 1st / 2nd.. idles just a bit lumpy.. have yet to rev it past 5k ~ 11in of vacuum at 800 rpm. Overall I'm happy with the way it behaved on the street over the weekend. I'm no expert ... just relaying my experience...
Old Nov 24, 2010 | 10:24 AM
midyearvette's Avatar
midyearvette
post# 17 says it nicely....
what are lifters with the oil hole??.....you guys aren't talking about the rockwell hardness test by chance??
Old Nov 24, 2010 | 10:34 AM
tt 383's Avatar
tt 383
EDM lifters or direct lube, then their are also lifters that have a groove cut along the body to dump oil onto the lobe as well, but the EDM seems like a better way.
Actually the grove is in the lifter bore.
Old Nov 24, 2010 | 10:57 AM
Les's Avatar
Les
This is the best pic I could find. The small hole in the face of the lifter allows oil to travel through the lifter to improve lubrication between it and the cam lobe.
http://cgi.ebay.com/ebaymotors/Crowe...#ht_1604wt_804
Old Nov 24, 2010 | 01:17 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
JIM
IMHO old school will always be
While taking care of a couple other small projects over the Holiday I'll try to find that thing and post a pic of it.
update - Haven't been able to lay my hands on it yet, which has me somewhat perplexed, but the search did turn up a few spare mushroom lifters. The tool consists of a shaft, lifter bore guide and cutter which slots onto the shaft from below. Attached to a 1/2 HP dril and generously lubed, all 16 bores can be clearanced in an hour or so, deburring not included.
Old Nov 24, 2010 | 01:38 PM
midyearvette
thanks guys.....back in the day isky "chilled iron" lifters were rockwell tested with a hole like that, i wonder if ir evolved into an oiler??
as an aside, why do solid lifters cost more now than hydraulics??....i remember in the early 60's solids were 18.95 a set and crane anti pump up hydraulics were 39.99 when i sold them at jegs.....
