Console light not working?
Old Nov 21, 2010 | 02:59 PM
jbaron's Avatar
jbaron
2017 C3 of the Year Finalist
Default Console light not working?
Was missing the socket on console shifter light. I put a new socket on & new bulb. Still no light. Is there a ground problem? What to check now?
Jim
Old Nov 21, 2010 | 03:25 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The console light works off the same circuit as the dash lamp bulbs. Are they working? If yes then maybe the ground is off the plate?
Did you test the circuit before you installed it to make sure the bulb connector and bulb are working properly?
Willcox
Old Nov 21, 2010 | 05:10 PM
jbaron's Avatar
jbaron
Dash lights all work. How is the light grounded?
The socket and bulb are new. I figured they were good.
Old Nov 22, 2010 | 11:30 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Do you have a metal console trim plate? If so, there should be a ground terminal on the underside of the plate at the top of the ashtray. The AIM shows it, but it's easy to miss.
It's a simple spade terminal, but it grounds the trim plate. The console wiring should have a black ground wire with a spade connector in it.
Old Nov 22, 2010 | 05:33 PM
jbaron's Avatar
jbaron
Thanks, hope that's all it is, and the ground wire is there somewhere.
To Console light not working?
