backfiring when trying to start.
Old Nov 23, 2010 | 07:46 PM
meinthe73's Avatar
meinthe73
Default backfiring when trying to start.
Got a ls1, and it runs and idles great, but some times when I try to start it this is what happens "turn the key on.your hear the fuel pump kick in,crank it ,the motor trys to turn on,crank it again then POP POP(from each exhaust),crank it again and fires right up."what could it be i've checked everything.
Old Nov 23, 2010 | 09:27 PM
dannyman's Avatar
dannyman
Double check your firing order.
Old Nov 23, 2010 | 10:02 PM
midyearvette's Avatar
midyearvette
popping or a backfire from the exhaust usually means there is raw fuel in the exhaust system that is ignited by starting the engine...
Old Nov 23, 2010 | 10:06 PM
meinthe73's Avatar
meinthe73
Interesting...how can this be solved? I'm running o2 sensors too
Old Nov 23, 2010 | 10:10 PM
meinthe73's Avatar
meinthe73
In the ecu?
Old Nov 24, 2010 | 06:17 AM
baxsom's Avatar
baxsom
In the ecu?
spark plug wires on the correct plug.
Old Nov 24, 2010 | 08:04 AM
pws69's Avatar
pws69
"it runs and idles great, but some times when I try to start"
Old Nov 24, 2010 | 10:14 AM
midyearvette
im assuming it is an injected engine??.....if so, you could have an injector leaking down or something in the computer delivering fuel at the wrong time....
if a cylinder fills wit fuel and dumps it into the exhaust while not on the firing stroke, this will ignite at start up and cause a pop or backfire and maybe even stall the engine
To backfiring when trying to start.
