Bee Jay's heavy a$$ door weight reduction mods!
Old Nov 24, 2010 | 03:15 PM
Bee Jay's Avatar
Bee Jay
Default Bee Jay's heavy a$$ door weight reduction mods!
I've been travelling, but I'm home for a couple of weeks. I decided to finally tear into the heavy a$$ door and see about losing some weight there. After removing the interior trim, you see that there is a almost a solid metal wall. Using my hole saw, dremell, and sawsall, I removed more than two lbs of uneeded metal panel. This gave me acess to the gaurd rail style door beam. Using my angle grinder, I cut the beam in two places and got about 80% of it out. What a pain in the ***. You have to be very paitient, especially when removing the beam in one piece. I shattered my passenger window. I should not have used that crow bar. Any ways, the beam weighed over 8 lbs, so I removed 10 lbs from the door. Actually more than that if you count the window. So, where is the best place to get a '79 Corvette passenger side window. Once I replace the window, I'll weigh the door. Then I'll weigh the drivers door for an accurate comparison, and then lighten it. Don't worry, it should be easier the second time and I won't break the window. It will be the hardest 20lbs I ever lost, but I'm moving toward my 3000lb goal.
Bee Jay
Old Nov 24, 2010 | 03:38 PM
Bob Heine's Avatar
Bob Heine
I usually find the most expensive and least responsive place to buy my stuff but I would try my local glass shop and see how much they want. Don't know if this is a good price but it's a starting point and at least you know it's available.
http://www.autocityclassic.net/index...mart&Itemid=48
Old Nov 24, 2010 | 03:40 PM
zwede's Avatar
zwede
Damn, that's pretty hard core!
Old Nov 24, 2010 | 04:24 PM
panic's Avatar
panic
BJ...you can leave only the outer FG shell of each door and cover it inside with a basic Ecklers panel, C3 doors are horribly heavy, I think I lost about 20 lbs per door (if not more)...
Old Nov 24, 2010 | 04:40 PM
Mashman's Avatar
Mashman
All that extra weight you are removing was added to the design in 1973 to provide additional passenger safety in an accident.
I wouldn't necessarily call it 'unneeded' - I wish my 72 had come with it!
Old Nov 24, 2010 | 05:14 PM
v2racing's Avatar
v2racing
Bee Jay, your a mad man! That's a lot of work for a little weight. What do you have for a hood on that car. They lightened them in 80. I have had the hood off and on my 80 several times. It's fairly light. I just took the hood off the 75 for the first time to start fitting the Ecklers L88 hood. I about sh*t when I picked up the 75 hood. It has to weigh double what the 80 hood does and even more than that over the Ecklers hood.
With your bumpers gone and your side protection now gone, I hope you never get hit in that car.
Old Nov 24, 2010 | 05:23 PM
dar322's Avatar
dar322
St. Jude Donor '12-'13
BJ, You feeling ok? Cold weather got you down? Before you chop up your car anymore, maybe you should book a vacation somewhere. Anywhere. Just get out of the garage.
Old Nov 24, 2010 | 06:19 PM
Bee Jay's Avatar
Bee Jay
I hope I never get hit in this car either. But it's safer than getting hit while on my Harley. The bumpers were only good for 5mph front and 2 1/2 mph back. I'm now as safe as any pre '74 Vette.
Yep, I gotta do something about the heavy hood soon. How does the 80 hood compare to the Ecklers aftermarket hood?
Bee Jay
Old Nov 24, 2010 | 06:23 PM
Bee Jay's Avatar
Bee Jay
Panic!!!? How the hell are you? Where are you? It's been a long time. I'm following in your footsteps. I'm going to lighten this car as much as possible, and then increase displacement of the engine. Like Zora said, boring out the engine increases horsepower, and saves weight". Any recent mods to one of my favorite cars?
Bee Jay]
PS I gotta have power windows, so I think I'm done with the doors. Unless someone makes a lightweight replacement for the power window motors. I save a ton when I replaced my starter with a new modern gear drive starter.
pauldana's Avatar
pauldana
buddy..... im speechless..... I..I......I...... speechless...
ps.... put in the steering bearing... 98% tighter then when you drove her.... I can tell now that the rest of the slop, is in the upper steering column bearing. next job......but much happier now...
o... and put in a 383....easy hp
Old Nov 24, 2010 | 06:33 PM
v2racing's Avatar
v2racing
Bee Jay
I don't have a weight on either hood, but the 80 is light compared to the 75, huge difference, and the 75 has a big hole in the center of it! The Ecklers feels lighter than the 80 hood.
Old Nov 24, 2010 | 06:54 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Dang Bee Jay, that is getting serious about weight. Hats off to you for not being shy about modding, but between the two I think I'm more likely to loose the PW's than remove the side impact beams.
Old Nov 24, 2010 | 07:13 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
you mean basic door panels as in not deluxe or just a skin of a door panel?
the both of you need aluminum blocks now. I have my rodeck sitting in the back yard waiting for me to build her.
Old Nov 24, 2010 | 07:28 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I've been waiting for some updates on the new engine build.
BeeJay: What does your side window weigh? I've heard the later glass is lighter (I obviously have the older, heavier stuff) and I'm curious if the difference is worth the cost and hassle.
Old Nov 24, 2010 | 07:40 PM
TheSkunkWorks
...I have my rodeck sitting in the back yard waiting for me to build her.
Let me know if you need some Rodeck valve covers to go on it.
Old Nov 24, 2010 | 07:50 PM
Alex/plus's Avatar
Alex/plus
If you ever decide to sell it make sure you have it in writing that it's for off road use only.
Deliberate removal of safety equipment will become a nightmare lawsuit if something should happen with the new owners.
Beware of all lawyers above sea level !!!
Old Nov 24, 2010 | 08:24 PM
Bee Jay's Avatar
Bee Jay
I bought the car new in 1979. Never gonna sell it.
Bee Jay
To Bee Jay's heavy a$$ door weight reduction mods!
Old Nov 24, 2010 | 08:26 PM
Bee Jay's Avatar
Bee Jay
I've heard that too. But everywhere I've checked for a replacement window, they simply list 74-82 Corvette Coupe. $139 seems to be the going price.
Bee Jay
Old Nov 24, 2010 | 08:27 PM
Bee Jay's Avatar
Bee Jay
Yea baby. Dart aluminum 427. Someday.
Bee Jay
Old Nov 24, 2010 | 08:30 PM
Bee Jay's Avatar
Bee Jay
Fact or fiction Paul, is the rack and pinion lighter than stock? By how much?
Bee Jay
