exhaust X pipe
Old Apr 5, 2002 | 08:10 PM
corvette4life's Avatar
corvette4life
Default exhaust X pipe
I've got dual exhaust on my 78. I'm considering a X pipe. Where did you cut yours in? Did it change the sound? How much did you have to pay?
Thanks for the help
Kerry
Old Apr 5, 2002 | 11:24 PM
corvette4life
Default Re: exhaust X pipe (corvette4life)
just hoping for some ideas.
Old Apr 5, 2002 | 11:53 PM
thermoquad's Avatar
thermoquad
Kerry--
Try a search of old topics--there was a very good thread on this not long ago, complete w/pics of the finished exhaust system. An exhaust shop in Norman priced an x-pipe setup to fit my 79 from headers to mufflers at around $215.00 this week.
Good luck.
Old Apr 6, 2002 | 11:27 AM
kenko74's Avatar
kenko74
Here's something I posted a couple seeks ago:
All,
Last week I asked you how to reduce the annoying resonance on my chambered exhaust, and several of you suggested I add a crossover pipe.
On my car, I had room behind the frame crossmember, just behind the tranny, and added a 2" crossover (to my 2 1/2 " system). I also had them add a flange in the middle, in case I ever needed to remove/loosen just one side of the exhaust.
Today I drove it through all RPM ranges :D and can say the crossover works well! (not perfect, but makes a noticable difference) While I still have that terrific loud sound and deep notes, I have greatly reduced the annoying resonance and vibration in the 1200-1500 RPM range.
Cost $60 parts and labor.
Important performance note: If you have this job done, my tech says it needs to be done in four steps: Step 1: they cut holes in my existing exhaust and welded in the 2" cross piece with the flange. Step 2: they then cut my exhaust pipes in half about an inch behind the new cross piece and used a fine cutting torch to remove the protusion (the 2" cross piece was cut square and protruding into the 2 1/2" exhaust pipe nearly an inch) This ensures a smooth exhaust flow. Step 3 is weld the exhaust back together, and step 4 is to apply high temp aluminized paint to the welded areas to prevent rust.
I'm quite pleased :cheers:
To exhaust X pipe
