Storage compartment
Old Nov 28, 2010 | 09:10 AM
pwsusi's Avatar
pwsusi
Default Storage compartment
Quick question -- I purchased a new storage compartment frame as well as the three frames for each of the storage compartment doors. I took the old storage comparment frame out and can't figure out how to get the hinges off to transfer over to the new one. There are metal rivits holding it in place. I'm hoping i don't need a special tool to do this.
Paul
Old Nov 28, 2010 | 09:29 AM
JimT's Avatar
JimT
Use a grinding wheel - a small one with a drill or a dremel tool. You can also drill them out - use a drill bit the same size as the rivet.
Old Nov 28, 2010 | 10:12 AM
redwingvette's Avatar
redwingvette
When I replaced my carpet years ago I was given small flathead woodscrews to replace the rivets with.
Old Nov 28, 2010 | 10:14 AM
Alan 71's Avatar
Alan 71
Hi Paul,
+.... when you re-attach the hinges you need to be careful what kind of fastener you use. If the head is any thicker than the rivets you now see, the hinge won't close properly to let the latch on the doors catch.
Also, the hinge needs to be attached very tight against the frame or else the hinge and fastener really stress the plastic frame and crack it on each end of the three hinges when you open and close the doors.
Good Luck.
Regards,
Alan
Old Nov 28, 2010 | 10:38 AM
BBCorv70's Avatar
BBCorv70
Originally Posted by Alan 71
Hi Paul,
Good Luck.
Regards,
Alan
I used some pan head socket screws to reattach my hinges. There's very little room between hinge halves when the doors are closed.
Old Nov 28, 2010 | 12:31 PM
pwsusi's Avatar
pwsusi
Thanks guys. This was supposed to be the easy part of re-doing the interior. Seems there's always little things that come up that you weren't anticipating.
Old Nov 29, 2010 | 08:20 PM
ylose's Avatar
ylose
Agreed. It's such a flimsy frame....I would love a nice aluminum frame or something. It's definitely not the sturdiest design.
Old Jan 2, 2023 | 12:15 PM
Fast Dawg's Avatar
Fast Dawg
I bought seven acres of undeveloped land in 2020 and knew I was going to have a Corvette since one has been sitting in the garages of homes we’ve owned for decades. My solution was a 30x30 detached garage across the driveway from my attached garage. It’s an aluminum building that actually matches our house and It cost less than my builder adding a third garage bay. Use your five acres!
Old Jan 2, 2023 | 12:45 PM
TX427C3's Avatar
TX427C3
Active Streak: 90 Days
St. Jude Donor '06-'09,'22,'25
Posting on related thread LOL
Old Jan 3, 2023 | 10:10 AM
Capt. Doug's Avatar
Capt. Doug
Paul
Just changed mine and had the same delimma. Mid America Motorworks sells the kit to change that out. Just grind the old rivets off or you can drill them out. Then replace with new rivets. Not easy to get them right. Good luck.
Old Jan 3, 2023 | 11:13 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Necro thread of 12 years.
To Storage compartment
