'73 power window switch
Old Nov 30, 2010 | 04:48 PM
TERRY CLARK's Avatar
TERRY CLARK
Default '73 power window switch
Does the Power Window Switch have some sort of clip on the long terminal to hold the plug on ?
Thanx !
Old Nov 30, 2010 | 05:09 PM
oldsarge's Avatar
oldsarge
No clip, just friction fit.
Old Nov 30, 2010 | 05:17 PM
TERRY CLARK
Thanx. Why is one lug longer than the others?
Old Nov 30, 2010 | 05:20 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
It may just have pulled out some. I thought that they were all the same length last time I looked.
Old Nov 30, 2010 | 05:26 PM
TERRY CLARK
They are new !
Old Nov 30, 2010 | 05:30 PM
calif phil's Avatar
calif phil
I am not sure about your 73 but some GM models use a little colored plastic nut that kind of pressed on the long shaft to hold the connector on.
Old Nov 30, 2010 | 06:20 PM
Mashman's Avatar
Mashman
On my 72, there was not a nut or anything to hold the connecor on. And there was 1 'prong' that was longer than the rest - I think it was the center one on the drivers side.
Old Nov 30, 2010 | 06:51 PM
...Roger...'s Avatar
...Roger...
I don't remember the last time I saw the retaining nut but the nut also covered the stud because the stud is HOT. I cut the stud off so it doesn't come in contact with ground and cause a short or fire.
To '73 power window switch
