Overdrive units
Old Apr 6, 2002 | 10:47 AM
Black68Vette's Avatar
Black68Vette
Default Overdrive units
Is there any sort of overdrive unit that is relatively inexpensive and mounts up easily with a muncie 4 speed? I don't want to go thru the expense and effort of a 5 or 6 speed conversion, but would like a lower highway cruising RPM (4.11 rear). I've seen the Gear Vendors setup, but it wouldn't be much cheaper (if not more expensive) than a 5 speed conversion..
Anyone know of any others?
Old Apr 6, 2002 | 03:48 PM
74vetteman's Avatar
74vetteman
Default Re: Overdrive units (Black68Vette)
Autogear sells a muncie m-22 gearset that has a overdrive 4th gear. They claim that it is a bit noisier than the regular 4th gear, though. You would have to by the whole gearset (probably $800.00 +).
My original link didn't work, I will try to find the right link.
Try http://www.autogear.net
[Modified by 74vetteman, 1:51 PM 4/6/2002]
[Modified by 74vetteman, 1:53 PM 4/6/2002]
Old Apr 6, 2002 | 06:02 PM
mrvette's Avatar
mrvette
Considering the final overall costs, I can't see any other choice but a factory o/drive unit of auto or stick....and the simplicity of the overall install dictates this action....
even a ZF 6 speed is a simple install and looks cleaner than most other options...an automatic is easier yet by a fair margin...
too boot most of the options from add on companies offer less of an effective o/drive ratio than factory units...
.7 something for autos, and .5 for a 6 speed....
GENE
Old Apr 6, 2002 | 07:25 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
This is a tough one. I love my vette and want to enjoy driving it as much as I can being that I live where driving time is limited throughout the year. If I lived in a warmer climate, an overdrive would be an even easy upgrade, because I could benefit from it all year long.
If the cost of the O/D tranny is too much at this time for you, I'd consider changing the rearend with a 3 series and maybe something like a 3.36 ratio until you can do the O/D. Keep the 4.11 rearend for the O/D when you get one. I had to bite the bullet and get a loan for my tranny, but it'll be worth it being that I'm driving my car all the way to BG Kentucky for the Cruise In. If I didn't have the O/D, I wouldn't even consider this. Also, if I were in the market looking for a C3, IMHO one with an O/D would be an attractive option :) .
Old Apr 6, 2002 | 08:27 PM
Jvette73's Avatar
Jvette73
Can you fit bigger meats on the back? Taller tires will reduce the the cruise rpm. I know, stupid answer. You would need really tall tires to get the 4.11 to comfortable cruise rpm. What say some 40" gumbo mudders. :lol: 4.11 4spd has gotta be fun from the hole though :cool:
Old Apr 6, 2002 | 10:41 PM
70 LS1's Avatar
70 LS1
Default Re: Overdrive units (Jvette73)
Some of the Baldwin Motion Supercars came with an overdrive unit that mated up somewhere in the driveline. I don't know much about them, but have seen them on ebay every now and then.
Old Apr 7, 2002 | 10:20 PM
ylose's Avatar
ylose
Default Re: Overdrive units (70 LS1)
yeah, they were a very unique o/d and not much is known about them.
I had a Baldwin Motion Car book onetime, that had all the cars for each year they made...it was awesome and the paint scheme was amazing for its time on those cars... :cheers:
Old Apr 7, 2002 | 11:31 PM
75 Hot One's Avatar
75 Hot One
Default Re: Overdrive units (ylose)
Just consulted with my Motion Performance catalogue. They hade two overdrive units-one by Hone Manufacturing and one by Lawrence. The Hone unit attached behind the transmission and provided a 30% overdrive. The book says the Lawrence unit is a "differential mount" and could have been ordered with specific gear ratios giving overdrive or underdrive. Looks like both units required shortening the driveshaft.
Old Apr 7, 2002 | 11:55 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
For the cost, I don't like the Gear Vendors setup. I'd go with a six-speed. The installation isn't that bad, and the payoff is incredible.
Old Apr 8, 2002 | 09:30 AM
Black68Vette
Default Re: Overdrive units (75 Hot One)
What was the price on them? or do they have a website? Mostly I am looking for cost effective...
Old Apr 8, 2002 | 09:49 AM
ylose's Avatar
ylose
yep the Hones were called "Hone-O-Drive "
some other info....
"Gear Vendors (still being built) unit that is built in England and used in trucks and motorhomes now"
wonder if we could find one in a junkyard and rip it out....hrm...
Old Apr 8, 2002 | 11:39 AM
ZD75blue's Avatar
ZD75blue
the ultimate setup, would be a 5 speed with a gear vendors over/under drive setup...
1st gear with the under drive... {evil smilie grin thing}
To Overdrive units
