Lexan Windshield
Old Dec 2, 2010 | 01:03 PM
Young69Owner's Avatar
Young69Owner
Default Lexan Windshield
Anyone use Percy before? http://www.summitracing.com/parts/PHP-01241-2/
I have a large crack and I like to "upgrade" when things break.
Clearone has a kit that you have to cut yourself...I'd rather not. Also, does 1/8" vs 3/16" really matter? Both should be plenty strong - so lighter I would think is better.
Old Dec 2, 2010 | 01:19 PM
Corey_68's Avatar
Corey_68
Never used that company...
But you might want to check with local laws as some areas Lexan is not legal for your front windshield. Great weight saver bit it scratches very easily and discolors over time.
Old Dec 2, 2010 | 01:48 PM
Young69Owner
How did it scratch, wiper blades?
Old Dec 2, 2010 | 02:17 PM
TimAT's Avatar
TimAT
Lexan windows won't pass any state inspection I'll bet. Side, rear or front, unless the DOT approval is molded into them.
( I've never done anything that might be even somewhat illegal. I just couldn't find the mufflers that were in the sidepipes when I needed them so I just put the pipes back on without them).
Old Dec 2, 2010 | 05:23 PM
Young69Owner
I'm wondering if the state inspection guys would know or care...also, how does this law apply to 41 yr-old cars? Anywho, I'd love to take out my glasspacks, but I once had a cop threaten me about them as it is...
Old Dec 2, 2010 | 07:34 PM
Garys 68's Avatar
Garys 68
You'll save a few pounds, spend a few extra bucks, but lexan will scratch if you EVER use your wipers.
Old Dec 2, 2010 | 09:07 PM
Denpo's Avatar
Denpo
There must be some that are street legal.
Ferraris for instance don't have glass windshield and are road legal.
Old Dec 3, 2010 | 11:13 AM
markids77's Avatar
markids77
I worked for GE plastics in a previous life and there are various "hard coat" laminated versions of Lexan, but none are as hard as glass. I would expect that a plastic windshield would scratch in short order if the wipers get used. I also suspect a Lexan shield would be more expensive than a glass one... the stuff's not cheap by any means!
Old Dec 3, 2010 | 07:32 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
If you go with SpeedGlass, even tho it's got a scratch resistant coating I'd seriously consider tear offs, especially for road racing. Windshields, windscreens, visors and paint can take a serious beating out there.
Old Dec 4, 2010 | 03:32 PM
Young69Owner
You have my attention. What is a tear-off?
Old Dec 4, 2010 | 04:51 PM
TheSkunkWorks
They're similar to visor tear offs, except you apply them more like a widow tint that goes on the exterior. Whether or not you think it's worth the additional investment is up to you, but it's surely much easier to strip and replace. A couple of links that may help...
http://www.tearoffguys.com/101.htm
http://www.protint.com/Racing/to_racingoptics.htm
Old Dec 4, 2010 | 05:15 PM
lakebumm's Avatar
lakebumm
2022 C2 of the Year Finalist - Modified
We ran a stock car out at Southside Speedway back in the '80's. I purchased a sheet of Lexan from Cadillac Plastics and cut and fit it.
There wasn't much to it.
BILL SR
Old Dec 4, 2010 | 05:27 PM
Hotrod406's Avatar
Hotrod406
Ferraris have glass windshields just like every other production street car.
Lexan is not going to save any money over the long run. Just get the glass and be done with it.
Old Dec 4, 2010 | 06:24 PM
TheSkunkWorks
Originally Posted by Hotrod406
...Lexan is not going to save any money over the long run. Just get the glass and be done with it.
FWIW, it ain't always about saving money.
Old Dec 4, 2010 | 06:32 PM
Hotrod406's Avatar
Hotrod406
I hear you there! For some reason I thought the OP said something about saving money. My mistake. I still recommend against it though. Too easy to scratch. You'd see scratches just from washing the car. Not worth it on a street car.
Old Dec 5, 2010 | 02:50 AM
stinger12's Avatar
stinger12
Get a glass one and be done with it. Upgrade your motor with the extra cash to make up for the weight of the new glass.
Old Dec 5, 2010 | 02:39 PM
tfi racing's Avatar
tfi racing
Did anybody mention yet how easy it will be scratched?More important than that,it just won't look good.
Also,why is it when someone asks about almost ANY modification,someone has to warn that it is against some law,real or imagined, somewhere?
To Lexan Windshield
Old Dec 5, 2010 | 03:57 PM
panic's Avatar
panic
I have a lexan windshield in my C3 since 4 years, it indeed needs some extra care for cleaning and you can't use your wipers but the weight saving was enough pro for me for the change.
Old Dec 6, 2010 | 04:13 PM
TheSkunkWorks
The issue of practicality isn't necessarily black & white for all of us, as while this may not make sense for a DD it certainly does so for a racing/track-day car. A good many enthusiasts happen to fall somewhere in between; the nearer to the racing end one resides the more sensible are any such hardcore mods. That said, not everyone defines performance solely by 1/4 mi ET's (nothing against drag racing, BTDT), and simply adding more power doesn't help in corners or under braking.
Also, we're not exactly talking about using something off the shelf from the big box store down the street here. Besides, every light aircraft in which I've ever flown has had plastic windscreens/windows of one sort or another, and IMOE as long as you don't fly thru a flock of large fowl they can last a good many years with proper care. Admittedly, this care is critical, so do keep Bubba a distance away from it.
Old Dec 6, 2010 | 07:04 PM
Bee Jay's Avatar
Bee Jay
I want the 78-82 rear window. I wonder if I'll have to rivet it in, or can I install it like a glass window.
Bee Jay
