Unknown electrical part
Old Dec 5, 2010 | 03:28 PM
sassc3's Avatar
sassc3
Default Unknown electrical part
On my 72, attached to the side of the dash top pad reinforcement, is a metal cylindar part that has a plug with pink and green wires connected to it. I can't find it in the AIM. Anybody know what it is?
Old Dec 5, 2010 | 03:56 PM
TimAT's Avatar
TimAT
I don't see it the 72 wiring diagram either. Nothing I found has a pink/green combination except the backup light switch and that's in the console (auto) or on the trans (manual).
I recall something about a wiper thing that was on the back of the speedo in some years but no idea what color the wires are.
Last edited by TimAT; Dec 5, 2010 at 04:36 PM. Reason: Someday, I'll learn to type and spell!!
Old Dec 5, 2010 | 04:08 PM
sassc3's Avatar
sassc3
I recall something about a wiper thing that was on the back of the speedo in some years but no idea what coler the wires are.
I think you mean on the back of the tach. I have it, so it's not that.
Thanks for trying.
Old Dec 5, 2010 | 04:23 PM
...Roger...'s Avatar
...Roger...
Didn't 72s have a light that flashed for a short time and then went out ? I was thinking it might be that.
edit-sassC3 , I think I found it on a diagram , I PMd you a link to it.
Old Dec 5, 2010 | 07:29 PM
oldsarge's Avatar
oldsarge
Not looking like anything stock, where do the two wires go. Have you traced them back to anything.
Old Dec 5, 2010 | 07:40 PM
mrvette's Avatar
mrvette
Pink and Pink/black should be a switched hot....like your dizzy....
trick is, what that green wire goes to.....
and I have a '72 vert which WAS stock as a stove and absolutely NO recollection of that device on my car...not even a hole/hole set to mount it there....
lemme know, please, if I miss the solution....
Old Dec 5, 2010 | 09:18 PM
sassc3's Avatar
sassc3
No idea abut the lights and what they are supposed to do. No interior lights have worked since i got it.
Roger, you must be right. With the info you gave me, I went and followed the pink to a lamp. At least I know the two go together. Thank you very much!
And yes, it looks stock. I removed all the black tape type stuff the harness was wrapped in. Looks stock to me.
Old Dec 5, 2010 | 09:22 PM
Gordonm's Avatar
Gordonm
My early 72 has that in there also. The 72s did have a light that went on only for about 20 second. It illuminated the seat belts light in the console gauges if I remember correctly. This may be for that.
Old Dec 5, 2010 | 10:16 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
That is what it is. A time delay relay that turned on the "Seat Belt" warning light for a few seconds when the ignition was turned on; this would happen if the seat belts were fastened or not.
Old Dec 5, 2010 | 10:19 PM
Duane4238's Avatar
Duane4238
Could be part of the circuit for the seatbelt warning buzzer and light in the center dash console. I have a '72 vert and when the ignition is turned on and the seatbelt is not connected, the red light in the center console lights and there's a warning buzzer with that, too. It'll buzz forever, not 20 seconds. The only way to shut it up is to connect the seatbelt or pull up one click on the hand brake. That stops the buzzer and puts the light out. Can't do much checking for you now, as the Vette is covered and buttoned up in the back of the garage for the winter. Sorry 'bout that!
Old Dec 6, 2010 | 12:53 AM
whitehause's Avatar
whitehause
The pink and green on my 68 is the back-up lights, they sure changed things in a few years.
Old Dec 6, 2010 | 11:37 AM
jnb5101's Avatar
jnb5101
my 72 harness has two sets of pink and green. one with the b/u light connector and the other with something different. both are electrically the same.
Old Dec 6, 2010 | 04:41 PM
Mashman's Avatar
Mashman
I agree with all those who stated that it is the thermal delay for the seatbelt warning system.
That system is unique to only early 72's. Very early 72's had this simple system where the seatbelt warning light was illuminated for a brief period of time, and turned off automatically.
Later 72's had a more complex system that included switches in the seatbelt recievers, a pressure switch under the passenger seat, a tie in to the nuetral safty so that system was only activated in foward gear, and a buzzer to go along with the light.
Old Dec 6, 2010 | 05:09 PM
...Roger...
Interesting, I learned something today ! Did the thermal delay just turn the light off or did it flash a couple times first ?
Old Dec 6, 2010 | 05:11 PM
Gordonm's Avatar
Gordonm
My 72 is an early built, August 71 car. The wiring harness actually has 71 on it. There is no signs of any connecters for the seat belts.
The light would just come on and stay on for 20 seconds then go off.
Old Dec 6, 2010 | 05:18 PM
...Roger...
Is this unknown part the part that looks like a starter buss for a florescent light ?
Old Dec 6, 2010 | 05:21 PM
Gordonm's Avatar
Gordonm
Yes
To Unknown electrical part
Old Dec 6, 2010 | 05:23 PM
mds3013's Avatar
mds3013
That is what I thought it looked like also. Did '72's come with a black light? mike...
Old Dec 6, 2010 | 05:50 PM
...Roger...
Yes
Interesting , I buy old harness's at swap meets to use for parts and I would have sworn the harness was a 73 but it had one of these thermal delay things. Must have been a 72 harness ! Thanks.
Old Dec 6, 2010 | 06:53 PM
7t2vette's Avatar
7t2vette
My 72 is also an early car, #456 built in August 71. When I was restoring my car, I tried with no luck to find a replacement for that part. I ended up using an industrial 12v time delay relay to make it work. It's the big orange thing in the pic.
