Headlight doors not opening
Old Dec 6, 2010 | 10:21 AM
lavery48's Avatar
lavery48
Default Headlight doors not opening
Why is that when I pullout the headlight switch the lights will come on but the doors won't open? In turn, I can pull the little know under the dash and they will open.
Old Dec 6, 2010 | 11:44 AM
78IndyPace's Avatar
78IndyPace
Since your system is functioning when you pull down the manual override "pull-down" switch, I suspect the vacuum hose connections on your headlight switch are reversed. Not uncommon. In fact, this hose connection as shown in the diagram on "corvette-101.com" is incorrect. It is also incorrect as shown in the Assembly Information Manual (AIM) for my '78, and I have read that it is also incorrect in at least one other year's AIM.
For correct vacuum hose connections at the headlight switch, the blue-striped line between the headlight switch and the manual override switch "pull down" switch must be connected to the front (firewall side) port and the non-striped line from the check valve must be connected to the rear port.
Please post an update on whether this fixes you problem.
Good luck!
Jerry
Old Dec 6, 2010 | 11:47 AM
jdp6000's Avatar
jdp6000
Actually I prefer them your way. You can run them like fog lights shining through the grills or put them up.
Jim
Old Dec 6, 2010 | 02:21 PM
Peterbuilt's Avatar
Peterbuilt
Old Dec 6, 2010 | 03:31 PM
lavery48's Avatar
lavery48
Jim, I was always afraid I would get off somewhere and they would stop coming up at all. I don't mind it like it is but when I let my girlfriend drive at night she can never get them turned off...lol
Old Dec 6, 2010 | 04:19 PM
...Roger...'s Avatar
...Roger...
Try pulling the headlight switch out very slowly and see if they will come up,if they do the 2 hoses are probably switched.
When the switch is out do you hear hissing ?
To Headlight doors not opening
