Build your own run-in box....
Old Apr 6, 2002 | 10:38 PM
topless68's Avatar
topless68
Default Build your own run-in box....
The FCR board ran this thread some time ago, and I thought it might help some others also. After seeing the BB in the other thread (427 Rat-man's BB), it looks like he started his out of the chasis. In this post you can see the box that Chuck S. built...obviously there was a lot of thought in it. If you try to run the engine on a build stand I would suggest bolting it very securely to your garage floor.
One more thing, the article is in an old NCRS Restorer volume from '99(?) I believe if you subcribe to it. If not I can fax it to you.
Run-in box
[Modified by topless68, 9:35 PM 4/6/2002]
[Modified by topless68, 9:36 PM 4/6/2002]
