motor issues
Old Dec 13, 2010 | 05:59 PM
MarkBullis's Avatar
MarkBullis
Default motor issues
Hey guys... got off work a little early today so i thought i'd work on the Vette a little...(figuring out the light problem) so i started it up after driving it this weekend and i heard a lifter rattling .. Also drove it up the road some and it felt like it was missing. So i brought it back home and called a buddy of mine and sure enough, he said the lifters needing adjusting and that I had two cylinders not hitting I need help! remember this is the 77 that had not ran for 18yrs and had been sitting, I've drove it about 100 miles since i got it and up until now it's ran pretty good until now, she's got 83k miles on my L48... What's the cheapest/best/most power i can do? Car is all matching numbers so i don't want to pull the motor if I don't have too.
Old Dec 14, 2010 | 09:25 PM
MarkBullis's Avatar
MarkBullis
Wow no one? Come on guys... Need your help!
Old Dec 14, 2010 | 09:33 PM
Timsride's Avatar
Timsride
If its as bad as it sounds it may need a new cam and lifters. I would keep it close to stock as You can if You want it looking totally stock. Just My 2 cents.
Indiancreek's Avatar
Indiancreek
There is only so much you can do without componant change of some type. Headers, intake and carb. Bolt on stuff. If you can't get the lifter issue to work and end up pulling the intake you could have some head work done.
Les's Avatar
Les
Try rephrasing your question. What you're asking is not clear to me.
Old Dec 14, 2010 | 09:51 PM
MarkBullis's Avatar
MarkBullis
My Question was i've got two cylinders not firing, I want to know what I can do to fix this issue and how hard is it to adjust the lifters? And while doing so what can i do to get more power out of my L48
Old Dec 14, 2010 | 10:30 PM
Peterbuilt's Avatar
Peterbuilt
Check to make sure that the "Bad" cylinders plugs, wires cap and rotor are good.
Heres a how to about valve lash adjustment:
http://www.centuryperformance.com/ad...h-spg-149.html
Old Dec 14, 2010 | 11:08 PM
rcread's Avatar
rcread
How did you diagnose the two non-firing cylinders?
Old Dec 15, 2010 | 06:42 PM
MarkBullis's Avatar
MarkBullis
replaced the plus,wires/cap/button, pulling the wire off for those cylinders and there's no fire, he said that i've got a lifter sticking on those cylinders or they're not firing because i've got bad rings... I know nothing about old motors... LOL if it don't have a computer on it i'm lost...
Old Dec 15, 2010 | 07:25 PM
wnmech's Avatar
wnmech
It sounds like first you need to get a compression check on those cylinders. It the engine backfiring out of the carburator or the exhaust? Are the two cylinders next to each other? Pull the valve cover off and see if there is any damage to the rocker arms or push rods. These small block engines are pretty tough.
Old Dec 15, 2010 | 07:28 PM
rcread's Avatar
rcread
Adding a quart of ATF to your oil might take care of sticky lifters.
Old Dec 15, 2010 | 09:06 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Damn. Sometimes the forum seems to be going to shet.
Old Dec 15, 2010 | 09:19 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Not so much adjusting the lifters, but you can adjust the rocker arms. Are the rockers clacking? adjusting the rockers is as easy as pulling the valve cover, put an oil catch on the ground, run the engine, and loosen the valves till they start clacking and then tighten until they stop plus a 1/4 turn. Now you could go and set lash with a feeler gauge and the engine not running if it is solid roller.
If you are not hitting on two cylinders i would check the plugs first and the ignition system. There is the possibility you have wiped some lobes on the cam. pulling the valve cover and inspecting the engine while turning it over should show you if the valves are opening properly.
Old Dec 16, 2010 | 09:03 AM
Phil Zell's Avatar
Phil Zell
Ditto
Check the camshaft, sounds like it is gone
Old Dec 16, 2010 | 11:14 AM
bashcraft's Avatar
bashcraft
I don't think your buddy knows much either.
Is the lifter or rocker arms making any noise? Are you sure you don't have those 2 plug wires crossed?
Old Dec 16, 2010 | 11:16 AM
straub18045's Avatar
straub18045
would of done a compression test before spending all the $. siiting that long maybe an oil waffer clot got caught in a oil orfice blocking flow? its winter time, pull it and freshen it up
Old Dec 17, 2010 | 01:20 AM
Les's Avatar
Les
As long as the motor sat without being run, as already stated by others, the lifters and/or rings could be sticking. For only a few bucks per can I'd try Sea Foam. Although I've never used it myself I've heard good things about it. At this point you really don't have much to lose. Here's a link with more info on it-
http://www.seafoamsales.com/motor-treatment.html
To motor issues
