Is it time to replace my composite spring?
Old Dec 15, 2010 | 09:36 AM
pinball08's Avatar
pinball08
Default Is it time to replace my composite spring?
1980 l82 vette,purchased the car in '98 already had a
composite spring installed.What is the life span of a composite spring?
thanks
kevin
Old Dec 15, 2010 | 09:54 AM
gkull's Avatar
gkull
When it breaks!
Old Dec 15, 2010 | 09:57 AM
mrvette's Avatar
mrvette
Originally Posted by gkull
When it breaks!
:c heers:
Thanks for the chuckle, best of the day, surely....and it's only 10 am......
Old Dec 15, 2010 | 11:06 AM
pinball08's Avatar
pinball08
When it breaks!
What in the wide wide world of sports......does that
mean?
Old Dec 15, 2010 | 11:17 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
I 'd have a good look at it , cracks chips sag, if you don't see anything wrong , leave it alone, but if your worried change it , short and easy job, Ron
Old Dec 15, 2010 | 11:35 AM
Rebelrob's Avatar
Rebelrob
PinBall, They should hold up unless they are cracked or damaged. They tend to hold their rate unlike the steel springs. I think your car came stock with the composite spring. Mine still has the stock spring and it still looks good. 80-82, except maybe for the 4 speeds, had composite springs. I am not 100% sure , but I think I am close.
Old Dec 15, 2010 | 11:44 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Everyone should check their composite springs from time to time, I have had two that were replaced because they cracked.
Not even enough to make one side sag but you never know if it is going to snap right off and that would create a mess
Old Dec 15, 2010 | 11:46 AM
v2racing's Avatar
v2racing
80 still had steel springs. The composite came out in 81.
Old Dec 15, 2010 | 11:51 AM
7T1vette's Avatar
7T1vette
Spring is good until it is cracked or has significant chip(s) on an edge. A chip will be the beginning of a stress-riser, which will propogate into a crack.
P.S. If you notice a chip on it, your best option would be to get a Dremel or air grinder and grind out the rough areas of the chip (removing as little material as possible). If the chip is "smoothed out" before it cracks, it may not develop a crack and will last a lot longer.
Old Dec 15, 2010 | 12:01 PM
gkull's Avatar
gkull
If it is not obviously defective it is good to go. I now use a VB&P 420# installed with exhaust pipe heat shields
Old Dec 15, 2010 | 12:20 PM
Vette5.5's Avatar
Vette5.5
If it's not sagging, wouldn't worry much about it. An inspection for crack's is a good idea on any spring, comp or steel. GM's been using comp spring's on Vette's and other car's for year's, with little reported problem's. Biggest problem with comp spring's is when a repair shop messes up on the hoist. A buddy spent good buck's for a comp on his 71', only to later find it wore a new steel job coming back from the shop. When confronting the tech's, was all blank stare's, with no one having a clue. He's still ticked, and never went back there for work.
Old Dec 15, 2010 | 12:26 PM
mrvette's Avatar
mrvette
Oh great, lovely to hear....
but gotta keep the exhaust pipes down off that spring too, they get to melting that thing you got troubles also....maybe fashion a heat shield if you concerned, my pipes are about 2" below the spring in center there....with no shield, Florida weather, been there 15 years street driven....
Old Dec 15, 2010 | 12:31 PM
GT's 78's Avatar
GT's 78
hey gkull, hows the ride with the 420???
Old Dec 15, 2010 | 12:34 PM
pinball08's Avatar
pinball08
I've owned the car for 12 years,dont know when the PO installed the composite spring.VPB has a sale on them now,if i did change it what # should i get
thanks Kevin
Old Dec 15, 2010 | 12:46 PM
dar322's Avatar
dar322
St. Jude Donor '12-'13
depends on the type of ride you want. Soft, easy on the bones for the street version or bone jarring hard for the racers.
Old Dec 15, 2010 | 12:56 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I've been running a 420# spring for the last 15 years (first with the original C3 suspension, and now with the C4 suspension), and the ride is very acceptable. There's also enough rear roll stiffness so that I was able to remove the rear bar, and the squat during acceleration (or rise under braking) is reduced.
Old Dec 15, 2010 | 02:13 PM
Vette5.5's Avatar
Vette5.5
Kinda wondering why removal of the rear bar, as only come's into play over one wheel bump's and cornering. Can make one wheel bump's a little harsher, but good to have in the corner's. Drag racer's usually pull em' off, but that's all stright line stuff.
To Is it time to replace my composite spring?
Old Dec 15, 2010 | 02:22 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
When it breaks!
mean?
Not that it's about to happen, but on occasion they have been known to fail catastrophically with little or no warning.
As mentioned, installing a stiffer rear spring will reduce squat under acceleration while shifting balance towards "loose" (unless you reduce/remove the rear bar in compensation) from wherever it is now.
Old Dec 15, 2010 | 02:38 PM
MotorHead's Avatar
MotorHead
I don't worry about heat, even from my 3 inch pipes. I wrap them with that one sided tin foil tape and then I put electrical tape around that so it all looks black.
I have measured the temp with a gun on the part that goes directly under the pipes and there was no difference in that part compared to the rest of the spring after an hour of driving in the summer
Old Dec 15, 2010 | 02:59 PM
69427's Avatar
69427
Question for you: What components determine the car's roll stiffness?
