new carb
Old Dec 16, 2010 | 04:12 AM
Phil5519's Avatar
Phil5519
Cruising
Default new carb
installed a new Edlbrock performance carb. Dose the timing change
Old Dec 16, 2010 | 02:59 PM
billsfan's Avatar
billsfan
Changing the carb does not effect the timing. You can always tweak the timing a little for better performance, but for daily driving the stock initial and centrifugal timing is just fine.
Old Dec 16, 2010 | 03:42 PM
LB66383's Avatar
LB66383
Just make sure you connect your vacuum advance to a manifold vacuum outlet on the carb.
To new carb
