Bolts missing from half shaft
Old Dec 18, 2010 | 10:19 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Default Bolts missing from half shaft
I'm tearing down the rear end of the car in search of a "thunk" and my passenger side rear axle, wheel side, is missing two bolts.
Is there anyway, other than looking, that i could have known they had come out? (noise/vibration, other?)
Old Dec 18, 2010 | 10:38 AM
wombvette's Avatar
wombvette
That thunk would be a clue.
Old Dec 18, 2010 | 10:44 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
I only heard the thunk from a dead stop, most often when pulling away from a stop sign.
First thing I checked was the bushing at the front of the diff, it was in great shape, so I waited until the winter to tear down the back end to find it.
http://www.facebook.com/photo.php?pi...8&id=515538771
Old Dec 18, 2010 | 11:01 AM
speedreed8's Avatar
speedreed8
for some reason that just doesnt look like the correct mounting for the half shaft to trailing arm, there should be a spindle flange on the half shaft that bolts to the flange on the trailing arm, never seen straps like that on the trailing arm. and the bolts should be secured with 2 french locks. hmmm. i dont see how a correct alignment could be done, or what keeps the half shaft centered, looks like it would be really out of balance. i wouldnt drive it like that.
http://www.ecklers.com/corvette-whee...1963-1979.html
http://www.ecklers.com/corvette-axle...roduct_Related
Old Dec 18, 2010 | 11:10 AM
Mike Ward's Avatar
Mike Ward
That's just weird.
Old Dec 18, 2010 | 11:25 AM
Gordonm's Avatar
Gordonm
That is not right at all. Get the correct flange and bolts. There is no way that can be aligned correctly. Without the flange there how did it bolt up correctly. How long was it driven like this.
Old Dec 18, 2010 | 11:29 AM
Steve439's Avatar
Steve439
I think it's OK, it just looks like a strap in the photo.
Notice the shape - a strap would be pretty flat along the edge.
I think the problem was the missing French locks.
Old Dec 18, 2010 | 11:46 AM
speedreed8's Avatar
speedreed8
you may be right Steve439, it looks decieving. anyway, it needs some locks. a common missing item. i know.
Old Dec 18, 2010 | 12:36 PM
Gordonm's Avatar
Gordonm
Looking at it closer it does look like the flange is there just the bolt is missing. Still not a good scenerio.
Old Dec 18, 2010 | 12:47 PM
Mike Ward's Avatar
Mike Ward
You're right. Looked all the world like strapping.
Old Dec 18, 2010 | 12:49 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
the other missing bolt
Old Dec 18, 2010 | 12:51 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Back to the original question, how could I have known they were missing?
Old Dec 18, 2010 | 12:53 PM
Mike Ward's Avatar
Mike Ward
There's a hole where the bolt used to be.
Old Dec 18, 2010 | 01:02 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Ha...ok...how about while driving?
Old Dec 18, 2010 | 01:03 PM
babbah's Avatar
babbah
Old Dec 18, 2010 | 01:04 PM
Gordonm's Avatar
Gordonm
While driving if the other 2 bolts were tight it would have worked fine. Now if you are putting some real power to it and dropping the clutch it may have sheared off the other bolts
Old Dec 18, 2010 | 01:20 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
When you hear a clunk, not trying to be funny here, when was the last time you checked the torque on the bolts holding your rear spring or the u-joint bolts on your driveshaft ? I think you will find your answer there.
There is actually not a great amount of force against those straps, you can kind of think of them as holding the u-joint caps in place, not really taking the full load of torque applied, also which ones are missing would make a difference too. I would take it apart and clean it and put another bolt in their with Locktite and you should be on your way
To Bolts missing from half shaft
Old Dec 18, 2010 | 03:42 PM
wombvette's Avatar
wombvette
The original french locks are missing. That obviously was replaced by lock washers, with should be OK. From the looks of that bolt hole the bolt is sheered off, and it was a recent happening. I see a lot of shiny metal showing there.
I don't know of any way you would have known if one was missing if the others were tight. But, either they all are loose or there has been some spirited driving to snap the other one. You should change them all and use grade 8 bolts.
Old Dec 18, 2010 | 04:13 PM
rcread's Avatar
rcread
Whoa, Mike. You're getting a little too technical on us, there.
Old Dec 18, 2010 | 05:59 PM
northern77's Avatar
northern77
I would like to see the other end of that shaft, could the shaft need to be end for ended?
