Harmonic Balancer for 72 LT-1
Old Dec 21, 2010 | 11:29 AM
vince6501's Avatar
vince6501
Cruising
Default Harmonic Balancer for 72 LT-1
I am buying a new harmonic balancer for my 72 LT-1. I am restoring the car back to original status. I do not have the original HB. I am buying one from Summit Racing since GM is no longer making that part. I just want to make sure that I have the proper size. I am seeing sizes that range from 6 to 8 in on this forum. Does anyone know the correct dimensions for the 72 LT-1 350 engine?
Old Dec 21, 2010 | 11:38 AM
69autoXr's Avatar
69autoXr
I believe the LT-1 balancer is 8" x 1-11/16". Look up PN 8571N at Year One. I plan to get my next one from there.
http://www.yearone.com/serverfiles/f...ain2.asp?cat=8
Old Dec 21, 2010 | 12:39 PM
wcsinx's Avatar
wcsinx
Pretty much any of these will work...
http://www.summitracing.com/search/D...Ns=Price%7cAsc
I got this one...
http://www.summitracing.com/parts/SUM-161358/
Seems to be a quality piece and it has 60° worth of timing marks ground into the face so I don't have to screw with tape.
Old Dec 21, 2010 | 02:38 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Are you purchasing this as part of an engine rebuild? Or are you swapping HB's on an existing engine?
If it's only a HB swap, have the new HB balance matched against the old one.
Old Dec 21, 2010 | 03:11 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
The original balancer was neutral balanced, so no need to do anything special.
Old Dec 21, 2010 | 05:35 PM
Alan 71's Avatar
Alan 71
Hi Vince,
72, LT-!, NICE!!
Since you're "restoring the car back to original status" have you considered trying to find a good used balancer?
Just a thught!
Regards,
Alan
Old Dec 21, 2010 | 06:44 PM
Two Red Vettes's Avatar
Two Red Vettes
Active Streak: 90 Days
SPAM alert!
I have the exact factory balancer you need. I bought it from Dr. Rebuild, painted it up Chevy orange, but never installed it (still in the box).
PM if interested.
Old Dec 22, 2010 | 03:06 PM
vince6501's Avatar
vince6501
Cruising
I am trying to stay as close to original equipment as possible. Does this one match pretty close to oe?
Old Dec 22, 2010 | 03:07 PM
vince6501's Avatar
vince6501
Cruising
That is the problem. I do not have the original HB.
Old Dec 22, 2010 | 03:17 PM
vince6501's Avatar
vince6501
Cruising
Originally Posted by Alan 71
Hi Vince,
72, LT-!, NICE!!
Just a thught!
Regards,
Alan
I have looked on Ebay but did not see any. Hard to find one when I don't know exactly what I'm looking for. Any thoughts on where to look?
Old Dec 22, 2010 | 03:46 PM
larrywalk's Avatar
larrywalk
http://www.summitracing.com/parts/NAL-88960604/
Old Dec 22, 2010 | 03:59 PM
vince6501's Avatar
vince6501
Cruising
I checked with Y1 and they can no longer get that one. GM is not making them anymore and that one is an OE part.
Old Dec 22, 2010 | 04:15 PM
Alan 71's Avatar
Alan 71
Hi Vince,
I didn't mean to imply that it would be easy to find, I was just wondering how original you were trying to be.
I'd try Paragon Vintage in Michigan, and Gale Gee Auto in Pennsylvania.
Regards,
Alan
Old Dec 22, 2010 | 04:52 PM
69autoXr's Avatar
69autoXr
Originally Posted by larrywalk
Interestingly the GM Performance Parts catalog lists this as an externally balanced damper, yet Summit says internal. Not sure who's right.
Old Dec 22, 2010 | 05:47 PM
73bbc's Avatar
73bbc
Vince,
If you're interested in a NOS original 8" balancer, I might still have the one that I bought in the 70's but never used. If I still have it I would consider swapping it for a Fluidamper if you're interested.
Old Dec 22, 2010 | 05:57 PM
larrywalk's Avatar
larrywalk
I saw that too, but when I checked the applications, it has to be the neutral balancer - I'm quite sure it's neutrally balanced.
Old Dec 22, 2010 | 06:26 PM
Solid LT1's Avatar
Solid LT1
Originally Posted by 73bbc
Vince,
This is the best offer out there, I have a used one and I would want $200 for it. If this guy really has the right thick LT-1 dampner and will trade for a "street fluid dampner" I would do it!
The ones Summit sells are too thin compared to the original LT-1 balancer.
To Harmonic Balancer for 72 LT-1
Old Dec 22, 2010 | 07:55 PM
69autoXr's Avatar
69autoXr
An older GMPP catalog doesn't list it as external. Also Jegs lists it as internal as well as Summit. It's also described as 1-11/16", which should be the correct thickness for LT-1.
Old Dec 22, 2010 | 09:20 PM
vince6501's Avatar
vince6501
Cruising
Thanks for the link. I ordered this one. I hope you are right. I had ordered another one from Summit (that was made by Dorman) but it was 6 3/4" and from what I hear on this forum, it is the 8" one that came on the 72 LT-1. Guess I will send the smaller one back.
Old Dec 22, 2010 | 10:09 PM
JE Caudle's Avatar
JE Caudle
My 8" balancer came from my local Chevy parts department. It's in there performance catalog.
HillBilly John...
