Steering issues
Old Dec 22, 2010 | 03:13 PM
gatewood8889's Avatar
gatewood8889
Default Steering issues
I just rebuilt my front end and steering systems. New ball joints, bushings idler arm, tie rods, control valve, hoses, power steering pump, and cylinder.
Now the steering wheel is very hard to turn and it does not seem to matter if you are moving or not. Although it is a little easier to turn when you are moving. I have bled the system and centered the control valve. Not sure what else may be causing this issue but it sure does suck to drive right now.
Any help is appreciated, Thank you in advance.
Old Dec 22, 2010 | 03:14 PM
gatewood8889
BTW it is a 1978 and I did put the pump on before i did the rest of this work so I know it is a good pump.
Old Dec 22, 2010 | 03:30 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
How full is the pump, and how tight is the belt?
Old Dec 22, 2010 | 03:35 PM
gatewood8889
The pump is full and the belt is pretty tight
Old Dec 22, 2010 | 03:44 PM
LB66383's Avatar
LB66383
Did you bleed the P/S system after you put it all back together?
Old Dec 22, 2010 | 04:05 PM
gatewood8889
yep, although I am going to redo that just to make sure.
Old Dec 22, 2010 | 05:54 PM
72LS1Vette's Avatar
72LS1Vette
As an experiment you could disconnect the ram shaft at the frame bracket and try driving a little to see if it steers easier. If it does you may have gotten a bad PS ram. And you are sure that you have all of the hoses connected correctly?
Rick B.
Old Dec 22, 2010 | 05:59 PM
gatewood8889
Well thats just the thing, I thought I had them all right but don't know how to double check that. I don't think it is possible to cross them to the pump but maybe to the cylinder can I just switch them from their current position? Will that hurt anything? or otherwise how do I check proper placement of those hoses?
Old Dec 22, 2010 | 06:18 PM
gatewood8889
Okay so I made sure that I bleed the system and that was not the problem I also checked to make sure that at least most of the torque specs were good and I could lift the car and move the wheels back and forth by hand the tire pressures are good and i removed the ram although I have not driven the car without the ram attached I did observe it with the car on jackstands and it extended when the wheel was turned to the left and retracted when it was turned to the right although fairly slowly and it did not seem like allot of power behind it. Keep in mind I have never seen one of these work before.
Old Dec 22, 2010 | 06:34 PM
72LS1Vette's Avatar
72LS1Vette
Take a look at this and see if it matches what you have now (click on Supporting Documentation to download the picture):
http://willcoxcorvette.com/repairand...lp.php?hID=129
Sounds a lot like the problem you are having.
Rick B.
Old Dec 22, 2010 | 06:52 PM
gatewood8889
That is how I have the hoses I am going to try just driving with it un attached and see if it gets easier. I dont know how one of these acts when it fails other than leaking?
Old Dec 23, 2010 | 09:29 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
What kind of ball joints? We had a Chevelle in here this summer and put some ball joints in it that were not from our usual supplier (customer supplied) and two of four were completely frozen. It's a thought...
Old Dec 23, 2010 | 06:42 PM
gatewood8889
They are free I can move the whole linkage when the car is up on jackstands. I am thinking that I have a bad power steering pump. Any recommendations on how to test that or what brand to buy?
To Steering issues
