1972 rear vibration
Old Dec 22, 2010 | 08:43 PM
rjm5's Avatar
rjm5
Default 1972 rear vibration
I have a 72 that has all 6 new U-Joints, wheels have been ballanced and it stil has a very uncomfortable vibration at 55 and up speeds, when I let of the gas the vibration is minimal or none at all. Any advise for me in curing this issue. Thanks
Old Dec 22, 2010 | 10:44 PM
wombvette's Avatar
wombvette
Make sure the camber alignment is not too negative.
Old Dec 23, 2010 | 12:56 AM
sly vette's Avatar
sly vette
Also the angle of the trans needs to be equal and opposite to that of the rear end. Naturally they have to be in line also.
Old Dec 23, 2010 | 01:07 AM
Two Red Vettes's Avatar
Two Red Vettes
Active Streak: 90 Days
Please explain.
Old Dec 23, 2010 | 01:20 AM
sly vette's Avatar
sly vette
For example.... if the trans sits at a 3 degree angle down the diff should sit at a 3 degree angle up to get the u-joints to work properly.
Old Dec 23, 2010 | 01:23 AM
Two Red Vettes
Excuse my ignorance, but is this something that should be measured when doing differential work?
If the angles you describe don't cancel each other, what do you do, use shims of some sort?
Old Dec 23, 2010 | 01:34 AM
sly vette's Avatar
sly vette
These things should be checked whenever the diff or trans is removed.
Shims can be used. I made a adjustable rear trans mount when I put in my T-5 5 speed and adjusted it to match the angle of the diff.
Look here http://forums.corvetteforum.com/c3-t...be-angled.html Or do a search on "drive train alignment"
Old Dec 23, 2010 | 08:18 AM
jnb5101's Avatar
jnb5101
auto or 4 speed? is this a problem that is new with the joints? any other work done on the rear suspension? were the spring bolts reinstalled to the original length? if it's an auto, when the car coasts most of the stress is off the driveline and engine rpm drops. if is a 4 speed the engine rpm's remain the same(of course), and vibration could be engine related. if the vibration has developed since the u joints were installed, look there. check the angle of the half shafts. they should be only slightly angled upward going from the wheel to the diffy. much is said about the propeller shaft angle, but the half shafts are much shorter, and therfore the angles are more critical. you may want to install longer spring bolts to reduce the half shaft angle.
Old Dec 23, 2010 | 09:08 AM
midyearvette's Avatar
midyearvette
often when this happens after new joints are installed, the culprit is the rear bushing or worn yoke at the trans. tailshaft
check for slop at the yoke.....good luck....
To 1972 rear vibration
