A/C Related Question
Old Dec 29, 2010 | 08:38 PM
raalonso's Avatar
raalonso
6th Gear
Default A/C Related Question
I have an 81 vette, AC works great but air does not blow from the top vents on the dash. Any idea why? Thanks
Old Dec 30, 2010 | 09:36 AM
tommyleea's Avatar
tommyleea
I have the same problem, but don't have an answer yet. It appears to be a blend door actuator issue, or the switch behind the control panel. On mine I do hear a hissing from the switch, so I am going to assume mine is the switch. I just haven't got around to taking it apart yet.
79vetter's Avatar
79vetter
You probably have a vacuum line that has come off - or is pinched up in the dash. You'll have to get in there and trace the vacuum lines to see where the issue is.
Old Dec 30, 2010 | 10:00 AM
raalonso's Avatar
raalonso
6th Gear
Thanks. I appreciate the reponse. I'll have to get in there and see what it is.
Old Dec 30, 2010 | 10:12 AM
Vette5.5's Avatar
Vette5.5
Symptom's point to an under dash vacuum leak, possibly an actuator. You're wanting to get this fixed very soon, as will cause the engine to run lean, and maybe affect the power brake's. If DIY, pick up a small Mity Vac hand held test kit to help with the diagnostic's. Good for bleeding brake system's, too.
To A/C Related Question
