Has anyone repaired their sagging outer door handle flap by replacing it with the spring that can be purchased from vendors or have one opted for the flimsy replacement "spring" that does not work in place of the regular spring?
I tried getting a new spring for mine and was told that they are getting away from the original design because that flap of steel works so good. The old springs are obsolete.It never worked for Me. I would try wilcox or Zip or Corvette Central for proper spring. The handle will have to be removed to replace spring though. You may be able to get a similar spring from local hardware store, someone posted something about that on here somewhere.
I doubt that you can find a spring of that configuration, size and strength at a local hardware store. But, you could make one out of a 'regular' local-store spring by cutting it down to the right length, then unwinding [about] one coil from each end. I would buy the right spring if I could locate a source (maybe buy two and save the other for the second door!).
The hinge pin on the door handle is a steel pin, the lid on the door handle is a soft pot metal with a chromed finish. The center holes in the handle lid will wear out over time from the steel pin wearing against the soft metal. Evidence of this is a lid that drags the side and/or the bottom of the inner handle cup!
Once they get to this point adding a "Helper" Spring to the handle may offer a little more life but it's only as good as the condition of the hinge it's helping. Of the lid is dragging then there is a good chance the hinge of the lid is worn out!
Originally Posted by Willcox Corvette
The issue with the outer door handle is not really the spring and in most cases its what the handle is made from. I'll explain.
Thanks for taking the time to explain that. In my case I opened the door and the flap only came up half way! So either I had to take a lot of things apart or buy the $2.00 spring.
It still works just fine years later.
I am not sure this is sagging door handle problem - but my door handle it sticking up too far. Just a little that it is noticeable and you can tell when you go to open it as well.
Is there a fix? or does this just happen once it gets worn out etc..
Hi Mark,
There are 2 'flags' that are part of the flapper that act as 'stops' for the flapper. If the 'flags' are missing or very worn, or if the pin the flapper pivots on is very worn, I guess it could allow the flapper to rise above the bezel on the body of the handle.
If the 'flags' are there and the handle is otherwise good I'd think a little shim could be glued to the flags to regulate where it sits relative to the bezel.
Be careful about buying new handles... there are some real junk handles available.
Regards,
Alan
Hi Mark,
Regards,
Alan
Very true, my father bought me one off ebay for something like $40 and the flap stuck after about 5 door openings. When I removed it, I found that rotating the pin would allow it to swing free but within a few uses, the pin would rotate again and it would stick.
Bought a more expensive but much higher quality one from Wilcox and it works like a champ!
