Big Block ID
Old Apr 8, 2002 | 08:25 PM
korvettekev's Avatar
korvettekev
Default Big Block ID
I have an obviously non-original Big Block in my car, I assumed it was a run-of-the-mill 454 out of some pick-up truck or something, until I looked at the block just above the oil filter boss. The block has HI PERF PASS 12 cast into it. Now I'm wondering, what is this thing?! The casting number for the block is 361959, and the serial Number is T0209TRU. Have I stumbled upon a 427?
Old Apr 8, 2002 | 09:15 PM
73-454's Avatar
73-454
Default Re: Big Block ID (korvettekev)
Based on your casting that is a 1973-85 454 car or truck block, not a vette engine for more info go to the following link http://www.nastyz28.com/bbcmenu.html
andyg's Avatar
andyg
From my chevy casting books, that number is from 73-85 for Chevelle's, passanger cars and trucks with a 454 block.
---Andy
Old Apr 8, 2002 | 09:18 PM
tworottiedogs's Avatar
tworottiedogs
361959.....454.......73-90...2 or 4 bolt
Old Apr 9, 2002 | 12:45 AM
mountainmotor's Avatar
mountainmotor
The rear passenger side of the block behind the head will be a cast code.That is the production date code.Post it and will tell you day,month and year made
Old Apr 9, 2002 | 12:53 AM
Tom73's Avatar
Tom73
This from the Mortec site about the HI PERF:
On big blocks, you may see the words "HIPERF", "HIPER", "TRUCK", "M.TRUCK", "PASS", "MAR" or "MARINE" cast into the block. You may see one or a combination of some of these words. First let me say that "HIPERF" or "HIPER" was used on ALL '65-'91 Mark IV big block blocks and is not an indication that it has four bolt main caps and was used in a high performance application. Two-bolt, low performance big blocks received the same "HIPERF" designation.
tom...
To Big Block ID
