Altrnator Help Please
Old Jan 2, 2011 | 04:06 AM
AAJC's Avatar
AAJC
Default Altrnator Help Please
Thanks for taking the time to read this.
I am having trouble with my alternator. It doesn’t appear to be charging, or the charge is not getting to the battery. Battery goes flat when parked for the week.
So far I have tested:
1. The voltage at the battery. 12.7 volts at idle. With lights on & revs up to 2500. 12.3 volts. Putting more load on the battery by switching on everything I can find. 12.2 volts.
2. The voltage across A & B, with ignition off, 12.7 volts. With Engine running 12.7 volts.
I then disconnected the red wire at B & tested the alternator at idle. 18 volts. Put the red wire back on & it went back to 12.7 volts.
Can anyone answer the following Please?
Should there be voltage running to the alternator at B when the ignition is off?
Why is the voltage different at B when the red wire is disconnected (at idle)?
What do the wires at C & D do???
Thanks in advance for your help.
Happy New Year
Old Jan 2, 2011 | 05:59 AM
hunt4cleanair's Avatar
hunt4cleanair
Can't help you with all the voltage comparisions but I picked up a Solar battery and charging system tester for $70.00 after attending a C5 tech session at Carlisle. Tester will isolate a test for battery health from the charging system and than permit a test to determine if charging system is generating voltage to restore battery use.
Old Jan 2, 2011 | 10:54 AM
'75's Avatar
'75
A is ground
B is Battery
C is sensing system voltage
D is for alt light if equipped or switched power
Your symptoms sound like you need to rebuild or replace the alternator.
Old Jan 3, 2011 | 12:50 PM
Mashman's Avatar
Mashman
Are you sure that you don't have a battery drain? There are a number of common causes.
Have you tried disconnecting the battery while it sits?
After the battery has died, and you've jumped the battery, what is the reading on the ammeter? Is it on the + side? How far, and does it go back down to 0?
To Altrnator Help Please
