Got A Couple Quick Questions
11" Pressure Plate Diameter
1-1/8" x 26 Disc Spline
My flywheel is a 168 tooth flywheel for a 454 and my transmission is a Borg Warner Super T10. Did I order the correct clutch?
2) I will be breaking in my engine by using my Quadra-Jet (spread bore) carburetor off of my 350. My intake is a square bore. I'm guessing I'll need to get a square bore to spread bore adapter plate huh? Could I get away without running one (just for break-in) or would the vacuum leak be too severe?
3) How do I figure out whether or not I have soft or hardened valve seats? Does anyone know whether or not my #215 heads came with soft of hardened valve seats?
4) I need to figure out what spark plugs I need. My heads are #215 which were used from 67-68, closed chambered and were used on 396 & 427s.
Thanks a bunch guys. I'm just rounding up my thoughts and trying to put 2 and 2 together.
That's not entirely true. You may laugh at this but on my dad's 427 tri-power he could never get the tri-power to work correctly. He ended up plugging up two of the two barrels and running off of a single two barrel on the 427 big block. Of course he never beat on it but you know. I haven't decided what I'm gonna do yet, I may throw the Holley 850 but I'm not sure if it's tuned at all or has a blown power valve. I don't want to be messing around with the carburetor and have it flooding on me during break-in. After break-in I won't mind tinkering with it and tuning it.
Tom:
The heads are from '67-'68 and came on 396s and 427s....most likely I don't have hardened valve seats unless the guy who owned them before me had them installed.
Bob:
Yea I bought the Center Force kit from Jeg's it includes the pressure plate and disc. I also bought the matching Center Force throwout bearing. I already have an adjustable clutch fork ball in my Lakewood bellhousing. Thanks for the tips.
That leads me to my next question....what is going to be the easiest way to drop the big block in? Should I drop the engine in and hook the tranny & bellhousing up or drop everything in at once. Or would I be better off to bolt the transmission in and hook the bellhousing up to my big block and slide the input shaft in and do it that way? :cheers:
I thought we got that point across to you before. Better to run it a little rich during breakin. Never lean...
:flag
Go buy a new carb. My brother tried to go the cheap route by installing a "swap meet" Edelbrock 750 on his 460 Ford. EVERYTHING was new EXCEPT that carb. Well, to make a long story short, he ended up scouring up the cylinder walls because of the "excessive fuel washdown". The carb flooded everytime on startup thus no lubrication on the cylinder walls. Cost him another $500 to get the machine shop to use a new block PLUS all that labor PLUS a NEW CARBURETOR. :mad :mad :mad :mad
YOU'VE COME THIS FAR, AND HAVE DONE EVERYTHING ELSE RIGHT. DON'T SKIP OUT AND TRY TO FIRE THAT MOTOR UP ON A USED OR A CARB THAT IS IN "UNKNOWN" CONDITION!!!
Bob :cheers:
That's why I am going to use my Quadra Jet. The Quadra-Jet is off of my 350 and was running flawlessly. I will richen the carburetor up a little bit and use it for break-in. After I have the engine good and broken in I will throw the 850 double pumper on and tinker around with it. I talked to my uncle about it and he sees no reason why the Quadra-Jet won't work fine for break-in. Thanks for the tip about what happened to your brother....that would be a real bummer :(.
